Old 09-01-2002, 12:33 AM
mdnnccivicrcr mdnnccivicrcr is offline
Z6/Y8 question...
I've got a dumb question, will a D16Z6/Y8 work without the vtec hooked up? Also, what will be the best vtec controller?
90 Civic EX *RIP*
90 CRX DX *RIP*
88 Civic DX Sedan (pushing boost) *RIP*
95 Accord LX Sedan
Old 09-01-2002, 12:56 AM
DRCustom DRCustom is offline
Send a message via AIM to DRCustom
What do you mean by work?
The engine will run, and you really won't be able to take it the whole way to redline (because redline will be lower without vtec)(Just fyi, I run right next to a 16.2 second car (I'm practically stock, and I once ran against one of those engines (withought vtec hooked up) in another CRX, and he was only a few car lengths behind me from start to about 70)).
An MSD RMP activated switch seems to be the cheapest vtec controller. The Honda vtec solenoid is the best.
Old 09-01-2002, 01:04 AM
QuickSilverEF9 QuickSilverEF9 is offline
Send a message via AIM to QuickSilverEF9
I heard the sohc vtec swap is good for mid 15s........ With some good mods good for low 14s... (head work)..
1997 Golf GTI VR6
-Leather Interior
-47000 miles
-JVC KDSH707 Head Unit
ON THE WAY
-2xInfinity Kappa Perfect 6.1 components
-12" Polk Momo sub
-JBL 600.1 amp
Future
-Brock B2 deep dish wheels
-Suspension.....
Old 09-01-2002, 03:34 AM
GTA's Avatar
GTA GTA is offline
Whee..
I think ami is still runnning without...did she get the rpm activated switch thing yet....??
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 09-01-2002, 10:18 AM
my reason for asking is because I'll probably spend $1k-$2k on one of those engines and after a hit like that I'll be looking for it to work in my car.
90 Civic EX *RIP*
90 CRX DX *RIP*
95 Accord LX Sedan
Old 09-01-2002, 10:49 AM
You could buy a b16 for that much...but the RPM switches are always floating around for less than 50 bucks, a friend of mine has one if you need it. Just let me know, he'll probably still have it.
Old 09-01-2002, 11:51 AM
Yes you could buy a b16a for that much but you still need about another grand in parts to get it to work in your car.
1997 Golf GTI VR6
-Leather Interior
-47000 miles
ON THE WAY
-12" Polk Momo sub
-JBL 600.1 amp
Future
-Suspension.....
Old 09-01-2002, 12:03 PM
A little over 2k will have it in my car with head work done, rebuild if nesscesary, a ss header, reground cam, aggressive ecu, short shifter, aftermarket lsd, vtec working, ignition system, and aggressive intake manifold. The initial swap could cost from $500-1200 depending if you do the work or have some1 else do it. Not turbo but well prepped SOHC vtecs have beaten b16s..... The b16a is great but its a trend and for the money I would spend to drop in I could have that swapped in a d-series swaped in with all the mods to whoop up on the b16s ass. I am not trying to build a track car. I want a fast streetable civic or celica People who sell b16s make a killing in japan the whole engine with everything costs no more than $300 and thats reaching. Why does everyone want to drop 4k on a b16? Because the trend says its the best and it looks better under the hood than a lil d series.
1997 Golf GTI VR6
-Leather Interior
-47000 miles
ON THE WAY
-12" Polk Momo sub
-JBL 600.1 amp
Future
-Suspension.....
Old 09-01-2002, 03:11 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
If you do swap in the d16z6/y8 I would recommend getting the appropriate ECU for the engine. It just makes more sense to use the ECU that was programmed for the engine. It might be more expensive, but your car will run better with the right ECU.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 09-01-2002, 04:13 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
my y8 is in, yes. vtec running, no. it feels like an a6 with a slight quicker response. why do i have no vtec? i'm fighting the injector battle. you might as well say it's running on 3 cylinders at the moment it sucks
the rpm switch works and is cheap however, not really worth it. save your $50 and apply it toward a p28 (92-95 Si/EX) ECU. the one main reason is it is has all the mapping set-up for the sohc vtec. sure the non vtec ecu works but, you lose a little. another feature (few people bring up) of the p28 ecu is: it flashes the check engine light for the ECU code...rather than pulling up your carpet to read a flashing LED on the ecu. it sounds stupid, but when you start doing swaps you end up checking that thing more than you ever would on a stock daily driver.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
