Old 08-31-2002, 11:31 PM
Drifter To Be Drifter To Be is offline
Catalytic Converter
What is a Catalytic Converter??
Sorry but I'm only 14 and a car enthusiast. (I want to get into Rally. maybe...)
Thanks
Old 08-31-2002, 11:43 PM
Scooter Bug's Avatar
Scooter Bug Scooter Bug is offline
Send a message via AIM to Scooter Bug Send a message via Yahoo to Scooter Bug
a cat converts the exhaust gases into nox. which is better than carbon dioxide
Becca
97 Civic EX
90 CRX DX
Old 08-31-2002, 11:48 PM
oh...
So that means that it makes the gases cleaner?
Less pollution??
Is that right?
Old 09-01-2002, 03:14 AM
yes sir
Becca
97 Civic EX
90 CRX DX
Old 09-01-2002, 02:18 PM
Fly Rice Racer's Avatar
Fly Rice Racer Fly Rice Racer is offline
Send a message via AIM to Fly Rice Racer
Straight Pipe
It's kind of like a filter. Consequently it slows down air flow when heading towards the muffler.
Most people take a hack saw to it and cut it out. Then they run a straight pipe in its place. This makes the car louder and gives you a few extra ponies in your pocket.
But in most states that is illegal so be careful if you decide to do it to your car when you get one.
PS what kind of car do you want?
7th Generation Civic Forever
Mods:
- Tanabe Super Racing Medalion Exhaust System
- AEM Cold Air Intake(Blue)
- AEM Air Bypass Valve
- REVO Short Shifter V2
- Kumo Sport DirectShift Conversion Kit Bushings
- Neuspeed Front Upper X-Brace Strut Bar
- MOMO Crystal Shift Knob(blue)
- M3 Power Mirrors w/ Turn Signal
- Ignited Push Button Starter(Blue)
- Hyper Blinker Strobe V2
- Shaved Emblems
- Tinted windows 35% on sides and 20% in the rear
- Sound System: Sony M650 head unit, Kicker SL7 12" Solobaric, and a bridged Rockford Fosgate 360a2 amp.
- Dynamated Trunk
Next Mod:
- Kamikaze Header 4-1 w/ Straight Pipe
- Apex-i VAFC
Old 09-01-2002, 02:23 PM
Re: Straight Pipe
Originally posted by Fly Rice Racer
PS what kind of car do you want? [/b]
I'm hoping RSX Type R but if not avaiable I'll just go with Type S
Old 09-01-2002, 02:29 PM
It's nice to dream isn't it. I wanted an RSX Type S so bad. But I had to settle for a Civic EX.
It's all good though. Cause I plan on doing an RSX motor swap. And I still would not have paid as much as if I bought an RSX anyways.
Mods:
- Shaved Emblems
- Dynamated Trunk
Next Mod:
- Apex-i VAFC
Old 09-12-2002, 07:48 AM
rx racer's Avatar
rx racer rx racer is offline
A catalytic converter is not a filter. What basically happens ins that you car uses gas and air for combution(burning). But unfortunately 100% of the fuel isnt burnt. What your catalytic conver does is take air from an air pump and uses it to burn up the unused fuel so you are not pumping gas vapours out while driving which would be bad for the environment.
Of coarse the catalytic converter restricts the amount of air flowing out of the engine thus you can get as much into the engine. which means less power. This is why hi flo cats give you more power, and no catalytic converter gives you alot of power. Its bad for the environment but i guess im just a bad guy.
1993 rx7
1994 Civic Ex
Old 09-12-2002, 09:56 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
From http://www.bba-reman.com/cats.htm
There are three basic types of automotive catalytic converters; Two-Way, Three-Way and Three-Way + Air. Each type uses a slightly different method and chemistry to reduce the harmful elements in exhaust emissions. Early model converters used a pelletised catalyst, but most modern converters are now designed with a free-flowing honeycomb ceramic catalyst. The type of converter required on a particular vehicle varies with model year, engine size and vehicle weight. Some vehicles even make use of more than one type of converter or a pre-converter to meet emission reduction standards.
A Two-Way converter, used on American cars between 1975 - 1980, oxidizes unburned harmful hydrocarbons and carbon monoxide into water and carbon dioxide. The first vehicles with catalytic converters had Two-Way reduction only capabilities.
A Three-Way converter is a triple purpose converter. It reduces nitrous oxides into nitrogen and oxygen. And, like the two-way converter, it oxidizes unburned harmful hydrocarbons and carbon monoxide into water and carbon dioxide.
A Three-Way + Air converter performs the same functions as the Three-Way converter. It oxidizes and reduces. The difference is the addition of secondary air between the two internal catalyst substrates that improves the oxidation capabilities of the converter. The secondary air is pumped into the middle of the converter between two separate catalyst coated ceramic substrates. The front ceramic performs the reduction and the back ceramic performs the oxidisation. Its like having two converters in one.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
