Old 08-31-2002, 11:30 PM
BMciv BMciv is offline
Tranny OIL???
Damn it's hard to find a 90-91 civic, anyways, I test drove this particular one, cleanest interior, but the stick shift was very stiff. Could this be the tranny oil? or the Clutch? Didn't seem to be any slippage though.
Old 09-07-2002, 07:37 AM
brownell brownell is offline
My 89 Civic had the same problem. The lubrication on the shift linkage (right underneath the shifter on the underside of the car) was all dried out. It is located right over the exhaust pipe and I figured the rusted off heat shields resulted in too much heat hitting the shifter linkage. I took apart the linkage, replace a couple of o-rings and lubricated with a high temp grease. It has been 2-3 years with no re-occurance.
Old 09-07-2002, 08:49 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
yeah that should work, you shouldnt have a problem after that.
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
