Old 09-23-2006, 03:16 AM
99avenger2.5 99avenger2.5 is offline
rear diff moaning
My friend just bought a 98 blazer LS 4X4 and their is a moaning noise that sounds like it is coming from the rear diff. the noise is their when accelerating but gets much worse when coasting to a stop. has anyone ran in to this problem before, and if so what was done to fix it?
Old 09-23-2006, 07:05 AM
Blue Bowtie's Avatar
Registered Offender
Re: rear diff moaning
Could easily be loose pinion bearings. Unfortunately, the proper repair would involve a nearly complete check of the gear contact and setup.
There is oil in the rear housing, correct?
Old 09-23-2006, 09:32 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Here is a site with some good info.
But it sounds like rear end repair time.
http://www.differentials.com/install.html
Good Luck and let us know how it goes.
MT
MT
Old 09-23-2006, 07:03 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
1.) You might be low on diff fluid.
2.) You might have a dry U-joint (Most plausible)
3.) You might have a bad pinion bearing.
I would say u-joint first. Do you ever hear a big clunk when you put it into gear?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-25-2006, 06:53 AM
98blazerRI's Avatar
98blazerRI 98blazerRI is offline
I had all kinds of noises comming from under my 98 blazer... Changed the U-Joints and everything was fine...
Old 09-30-2006, 09:28 AM
I didn't have the right tools to take the diff apart so i took it to the shop. They put a carrier bearing in it and that fixed it. it was about $250. thanks for the help.
Old 09-30-2006, 10:02 AM
MT-2500's Avatar
AF - Advisor
Thanks for posting back and letting us bnow how it went.
MT
MT
Old 09-30-2006, 03:25 PM
Registered Offender
That's actually not a bad price if the axle is now quiet (they must've got it shimmed correctly).
