Old 09-23-2006, 03:08 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
12.422 @ 111mph
Went to the track for the last time this year. It was in the 50's. I was running without the passenger side head light. I just installed 550cc injectors last night, so I sent about 20 minuets getting the wideband AFR with 50/50 h20/meth mix dialed in to 12:1 AFR. The first run was 12.78 at 21psi, I was getting 3.4 deg retard in the top of 3rd so I added fuel from 4500rpm +. Second run was a 12.5, same boost. for some reasion I was getting the same amount of knock so I let it sit for about an hour and added a couple more clicks on the fuel slider and ran a 12.422 ET, 1.76 0-60 foot at 111mph on 11.8 AFR & 21psi. For some reason I'm only getting 14 deg timing advance. There is definitly room to move on this turbo. I was only seeing 35lb/min. A little more practace, and some cams I'll be in the 11's on my full weight 2g next year..
Stock clutch, tranny, 7bolt, suspention, wheels/tires.
Had a good DSM turn out, got to meet a couple people I have only know on the new forum, didn't loose any races, and shatterd my 12.99 goal.. I'll post up a log tomarrow night when I get off work...
DSM geek
Old 09-23-2006, 10:38 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 12.422 @ 111mph
Awesome run! Thats good considering everything thats still stock. I can definetly see you touching an 11.99 with a few changes to your setup.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
Re: 12.422 @ 111mph
sounds like you would run even better if you went somewhere and got dyno tuned. the average cost is 100 and hour and its well worth it
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 09-23-2006, 10:49 AM
Re: 12.422 @ 111mph
Here is my Dsmlink log. It's not that nice. I'm extreamly happy with my results based on the log...
http://www.box.net/public/tl535fupi5
DSM geek
Old 09-23-2006, 10:58 AM
Re: 12.422 @ 111mph
What program do I need to read your log? I'd really like to see the details of it.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-23-2006, 11:29 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: 12.422 @ 111mph
yeah man there is definitely some room for improvement, but great job scott!
If you keep 60'ing like that you will only lower your time
I'm showing an ecu estimated afr of above 12 most of the time on 550s. Your wideband was showing in the 11's? I think your airflow is not being monitored correctly for two reasons. only 35lbs of air and you ran a mid 12? and also your boost estimate never gets above 18, and you say you were running 21, so that's a problem there. Also, is your boost falling towards redline? The log says it's falling. That's a 3bar right? so boostest is accurate? Did you dial in the injectors using ltft via link?
now - 2000 civic
soon - 2002 is300
Old 09-23-2006, 11:45 AM
E-Klips E-Klips is offline
Banned
Re: 12.422 @ 111mph
I'm guessing by the meth injection you are running pump gas?
You are pretty lean for pump gas. 10.8-11.2 is a good set of numbers to go by, especially if you are running meth injection. Meth is a lot leaner than gasoline at that AFR so you need to adjust your tables for that too.
12.4 is pretty impressive with 21psi. I'd bet with some more tuning and a little more boost, switch to race gas and you would probably see an 11.
Old 09-23-2006, 11:47 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 12.422 @ 111mph
Congrats scottsee, that gives me hope for an 11 on an Evo III 16g in my car. (I am teetering between Evo III 16g and the 50 trim now)
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-23-2006, 12:40 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Re: 12.422 @ 111mph
Awesome run man! I'd like to see a video of it next time!
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 09-23-2006, 02:20 PM
Re: 12.422 @ 111mph
I did get a video, I have to wait for a friend to host it on my forum.. I'll post a link tonight, or tomarrow. Thanks guys.. 220deg temps really killed 4th gear...
DSM geek
Old 09-24-2006, 09:34 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: 12.422 @ 111mph
for the video, also, what program is needed to view the log? i would really like to see it.
Old 09-24-2006, 09:44 PM
Re: 12.422 @ 111mph
download the software from Dsmlink.com
DSM geek
