Old 09-23-2006, 01:30 AM
rali5255 rali5255 is offline
1999 service engine soon
The service engine soon light comes on after short drive. The code PO401 means insufficient flow detected. I did the following:
  1. Bought a new EGR and install, resetting error code. After a few days the same error code PO401 comes up again.
  2. Install the original EGR but after cleaning the plunger and outer debris. The error code reset and after few days of driving the same error code PO401 comes on again.
  3. Took the EGR OUT and cleaned the vacuum piping with a wire and installed old EGR again after resetting error code. The problem comes on again with the same error code po401.
Some car history prior to this problem. The service light came on and the code was related to the MAF (mass air flow switch) which was replaced.
As soon as the MAF was replaced one day later this PO401 started.
Confused as to whats next. I had terrible Dealer experiences so prefer to fix myself.
Can someone help if you had similar problems.
Thanks..........
Old 09-23-2006, 09:57 AM
maxwedge maxwedge is offline
A990 racer
Re: 1999 service engine soon
Welcome to AF. Did you have the pcv valve replaced or an upper intake manifold done recently?
Old 09-24-2006, 03:41 PM
I did have the PCV valve replaced recently. No work done on the intake manifold.
Old 09-24-2006, 04:02 PM
A990 racer
Recheck your pcv installation you may have left out one of the 2 "o" rings. Omission of these seals can set that code especially larger one , easy to forget.
Old 09-24-2006, 04:43 PM
imidazol97 imidazol97 is offline
AF -Advisor
Thanks..........
Why did you replace the EGR valve?
Old 09-25-2006, 09:36 AM
Problem solved. (PCV valve I install was removed and original one installed).
The big O ring was in but the PCV installed had no small O ring.
Thanks for asking why I replaced the PCV valve. (When I installed the new MAF sensor I decided to replace a new PCV valve aftermarket for NO reason).
Lesson for me track one problem at a time.
So my original EGR in and the Original PCV in. My only problem was a MAF sensor. My new EGR removed soon after problem code re-occur.
Stock with a new EGR (Price with gasket $245.00)
Excellent site. Thank you so much.........
