| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
turbo charged or super charged
I am new to this place and i have bought a 98 chevy z28 with the LS1 and i a wanting to increase hp and not decrease the money. Please help
Re: turbo charged or super charged
It depends on what you are looking for. If your looking for something easy to hook up that will give you a nice bump in performance go with a supercharger. If you are looking for a kit that will deliver most possible potential in horsepowe but that will probably cost a bit more cause of the engineering that went into designing the kit go turbo.
Either way boost is boost and a turbo will not eat up as much of the potential power but will probably generate slightly higher engine bay temps and cost a tad more. Also what do you mean by decrease money. You mean value of the vehicle?. Cause vehicles with turbo's and superchargers generally sell for higher than stock vehicles. PS- Welcome to AF.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
Either way you go you're looking at spending between $4k-$6k. Each option has its pros and cons. for the S/C the pros are cooler inlet air temps, less problems with convection heat and simple belt & pulley changes to alter the boost psi.and almost instant boost. Cons are parasitic loss of some of the HP from turning the blower and limited pressures (on under hood designs).
For the turbo pros are more mounting location options, no parasitic drag, usually smaller in design. Cons are high temps, changing boost pressure usually takes a larger turbo, turbo lag and more parts involved. |
i think he means... he doesnt wanna decrease his pockets
![]() car audio guru...
Forced induction won't be cheap on any car.
Plus, you'll probably want a tune and bolt-on's to support the extra flow. But on stock internals, you'll only be able to run 6-8 pounds of boost anyway, and Formula is right, boost is boost.
Sold 1994 Camaro Z28 ![]() Current Car 2003 Monte Carlo SS ![]() Sold 2009 Kawasaki Ninja 500R |
turbo. accept no other.
Seatbelts Saved My Life
i hate how superchargers sound
Very true. There's a TT supra that drifts at the track around here, and it sounds amazing. I am a big fan of turbo's, but FormulaLT1 brought up some awesome points. If you were on a real tight budget, go supercharger and make the power in other(cheaper) areas.
any type of forced induction will not be cheap. bolt ons are almost mandatory to support and take full advantage of a blower or turbo. a supercharger kit will be cheaper and easier to install. One of the best turbo kits for the late model f-body is the STS system which locates the turbo in place of the muffler. that reduces under hood temps and saves space under the hood. either way you are looking at $3,000-$6,000 for a kit and some supporting bolt ons.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
remote turbo? not as efficient as a manifold-mounted one.
and c'mon, a turbo 7-ft away from the engine?
Again, I am all for turbo in 99.99% of the cases. Because they are more efficient and use mostly unused energy to drive them. They usually also provide power at a range that is more usable without creating tractions issue's and in most cases are easier fabrication wise to get in there somewhere when space isn't a issue. Now with that said, F-body's use large displacement engine's in already cramped to near max engine bays and because of this extreme, it is in dangerously close quarters to vital engine/wiring components, more piping/plumbing components complicates routing and find room to route things and because of this more time to design a practical kit is required. Time=money. Then you run into issue like needing a intercooler because of the higher intake temps of a turbo. I looked and weighed all factors in my decision and would have loved to go turbo because it is the superior design of the two but in my case and many other f-body owners IMO. Supercharger is the more practical boost method.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) Last edited by FormulaLT1; 09-24-2006 at 10:31 PM. |
where there's a will, there's a way.
my friend taught me that. pushing figures on some engines i couldn't even imagine.
