Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 09-22-2006, 07:34 PM
johnml johnml is offline
96 heater a/c dash control head
The compressor on my a/c stopped working, I had it checked out and I think I need a new dash control head. Does anyone no how that head comes out or anything else that I should check? Everything else on the control works.
Old 10-09-2008, 12:06 AM
hockey13 hockey13 is offline
Re: 96 heater a/c dash control head
did you check the compressor clutch the wire is right there above the pump. pull it off and check for voltage it maybe the clutch instead of the head.
Old 11-30-2008, 11:38 PM
homeskillet43 homeskillet43 is offline
Send a message via AIM to homeskillet43
I do believe I have a head unit for the Heat and A/C for a 1995 Lincoln Continental. If you want it, you are welcome to have it. I pulled that head unit out too long ago, but i can tell you that there are two small bolts on the back of the unit that are kind of difficult to remove. There are also about five vacuum lines that need to be rearranged the same way to fit the new head unit. Contact me using the private chat message, if you need any further information.
