Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-22-2006, 06:11 PM
Willyswagn Willyswagn is offline
Oil coming out of drivers exhaust
Ok gents,
89 sub 4wd with 350 engine. Engine overheated on my last trip but made it home, might be a bad thermostat as I flushed the system recently. Runs rough but doesn't smoke. Last time used it wants to stall. Thinking it might be bad egr valve. Have put in new plugs, wire, dist cap, rotor, pcv.
What I noticed is oil dripping out of the drivers exhaust manifold where it is connected to the exhaust. Oil has prob ruined o2 sensor which might cause the rough running? Yet doesn't smoke and starts up fine.
Any ideas?
Old 09-23-2006, 03:10 AM
dlog dlog is offline
Re: Oil coming out of drivers exhaust
From what you describe, it sounds like you have blown a headgasket?? Maybe I'm missing something here??
Old 09-23-2006, 05:58 AM
Blue Bowtie's Avatar
Registered Offender
How do the spark plugs in that bank appear?
Old 09-23-2006, 08:26 AM
Haven't pulled the plugs yet but there is no blue smoke out of the exhaust. Oil looks good and only down 1/8th quart.
Old 09-23-2006, 10:44 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Originally Posted by Willyswagn
Ok gents,
Any ideas?
Is the oil actually oozing out of the manifold (it would smoke like hell and you'd see liquid inside the tailpipe), or could it possibly be coming from a leak at the valve cover, running down onto the manifold?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-10-2006, 12:52 PM
update:
Yes it was the head gasket. Someone had opened the engine before and either bumped the gasket on installation or else part was bad.
In hindsite had been seeing a lot of grunge in the coolant overflow. Cleaned the cooling system twice in past few years. Plugs never showed a problem
