Old 09-22-2006, 05:24 PM
jonphelps1976 jonphelps1976 is offline
Transmission issue??
I have a 5.3 Z71 150k w/ 85k on tranny.
Truck runs fine on hwy but when sitting in stop light I get a real rough feeling, I don't think it's the idle, seems more like the transmission. If I put the truck in N or P, the roughness goes away. I only feel it when it's in gear. Also, it made a whining noise briefly, but it was not persistent. And it seems like the shifting is a little rough.
Any ideas? Is my tranny shot?
Thanks in advance.
Old 09-22-2006, 06:05 PM
Blue Bowtie's Avatar
Registered Offender
Re: Transmission issue??
Is transmission engagement normal, or slow to shift firmly into REVERSE and DRIVE?
Old 09-22-2006, 06:51 PM
Engagement is normal, it's after engagement that the rough idle begins. If I shift to N, the idle will spike up to about 2k rpm and then be smooth.
Is it possible that a vaccuum leak could cause this? But, why only when the truck is in gear?
Old 09-22-2006, 10:16 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
GMMerlin?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 09-23-2006, 07:43 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Originally Posted by BlenderWizard
GMMerlin?
You rang ?
Crystal ball alert went off this morning...so whats up?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-23-2006, 07:49 AM
GMMerlin's Avatar
I know stuff
The reason you feel the rough idle in gear is because the engine is under a load.
We will need some more detail as to what is happening on your end, but I have a couple questions.
Is this a rough idle or does it feel like the engine vibration is being transfered into the passenger compartment?
Does the truck have a lower then normal idle speed?
From what you are describing here , it sounds like you have a low idle and the IAC tries to compensate by raising the engine rpm...this is where you get the rpm spike.
SO many things could cause this its hard to know where to start.....
A couple ideas would be, check the TB and clean it. Check for vacum leaks especially at the area where the intake meets the heads.
GM WCT
PM Me for details
Old 09-23-2006, 08:55 AM
RE: GMMerlin
1. After messing with it again this morning it does seem more like engine vibration rather than rough idle. The truck will idle fine in P and N, and even in D when I'm not on the brakes. Once I press the brakes, the RPM's take a dive, and then the vibration begins within about 2 seconds. It's almost like the engine is missing...It's a sputtering feeling.
2. Idle speed seems normal. maybe a tad high, but probably just my imagination.
I will clean the TB and check for a leak today...any other ideas/opinions would be greatly appreciated.
Thanks.
Old 09-23-2006, 09:03 AM
wrparks wrparks is offline
Just my but yes a vacuum leak can absolutely do this. My wifes car had the exact same symptoms but it was also posting a misfire code. So, I changed plugs and wires all to no avail. When I went around the vac lines and sprayed carb cleaner, I finally found the leak b/c the engine revved up. Plug the leak and it ran perfect. Just goes to show, don't always assume that the code tells you what is wrong direcly huh? If you clean the TB, go ahead and spray some of the cleaner around the lines to check for a leak. Or you could use the tube in ear method of checking for leaks. It's cheap, and good insurance before you go spending money.
Old 09-23-2006, 09:29 AM
Tube and ear method??
I've got tubes and ears...please explain the method...this is my first go around with tracking a leak
Also, since the problem occurs when I'm on the brake, should I look around the master cylinder and brake lines for a leak first?
Thanks again.
Old 09-23-2006, 11:07 AM
GMMerlin's Avatar
I know stuff
RE: GMMerlin
Thanks.
Sounds like you have a vacum leak at the booster. When you put your foot on the brake pedal, do you hear a hissing sound inside the truck?
GM WCT
PM Me for details
Old 09-23-2006, 11:37 AM
I don't hear it inside, but with the hood up it makes a sort of clucking noise...But it's definately only a problem with brake on and trans engaged.
thanks.
Old 09-23-2006, 12:09 PM
I've never tried the tube method, but from what I hear, just stick a piece of tubing in your ear and take the other end and run it around the vac lines and you can hear a leak as a whistle. Again, never actually tried that one, but I know the carb cleaner works. Does it cause problems when it's in gear and the parking break is set but the brake petal is not engaged?
Old 09-23-2006, 12:18 PM
ha..I'll do it while nobody is around...i don't want my neighbors to see me stethoscoping my engine!
My parking brake is weak anyway...so I can't test that.
I've got some carb cleaner so I will start with that method. I'm just looking for bubbles right?
If it is the booster, it seems like it shouldn't be too hard to replace...even for a rook like me.
Thanks again to everyone..I never would have even known where to begin, at least now I have a good solid starting point.
Old 09-23-2006, 12:26 PM
muff34 muff34 is offline
"I've got some carb cleaner so I will start with that method. I'm just looking for bubbles right?"
the engine will rev up if you find a leak using carb cleaner
Life Is A Highway ,Enjoy The Ride
Old 09-23-2006, 12:29 PM
Okay. I will check this afternoon and post the results.
