Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-22-2006, 01:12 PM
Woowagon Woowagon is offline
valve adjustment 99 Passport
Anyone done it? How long did it take? What did you find? Comments?
Old 09-22-2006, 01:35 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: valve adjustment 99 Passport
don't need to. unless they are noise. I have never heard of a +98 owner having to do it.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 09-22-2006, 09:03 PM
Everything I have read says that the later (3.2L, 4 cam) engines have solid tappets. If true, at some point, the clearances will need checked/adjusted. Is my info wrong or do the valve clearances somehow just not change on these engines?
Old 09-22-2006, 11:13 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
They use a bucket and shim "direct attack" system. You change the shims to adjust them which gets expensive. I've heard you cant just buy one size, you have to buy a set of them. I havent heard of anyone with an isuzu with them that has had to do it yet (some have over 200k miles). I do know of some other vehicles that needed shims done, they just turned the bad one over and it quieted down.
There is no longer a check interval on these engines. Isuzu says only do it if a valve starts making noise.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 09-26-2006, 10:27 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
I have actually had to do one what a PITA I learned the best thing to do is just flip the stupid shim over to the flat side if the used side is concave at all
you will need special tools for this job unless you are very good at improvising as I have become ovr the years because I can never find any of the darn special tools
