Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-31-2002, 07:15 PM
darrahfc darrahfc is offline
Radio looses station/date memory
How do I correct this problem? When the car is turned off all memory is lost!
Thanks for any help.
Fred
Old 05-16-2003, 08:06 PM
ice745 ice745 is offline
AF -Advisor
on car radios there is usually multiple wires giving it power.
1 negative wire
1 Positive Accesory wire (gives 12 volts + only when the car is started)
1 Memory Wire (constantly gives 12 volts + for the memory of the radio)
and sometimes a wire for the dimmer (gives 12 volts + when the headlights are turned on.)
if you recently had a new stereo put in, or had service done to the car around the radio, the mechanic/installer may have accidently changed the memory wire to a accessory wire, making the memory wire lose it's power when the car is turned off, causing ur problem.
Old 05-16-2003, 08:08 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
check your battery terminals too, if they are corroded, disconnect then and use a wire brush to clean them.
Old 05-16-2003, 08:09 PM
AF -Advisor
also service done to the fuse box area or another part of the electical system, the mechanic/installer could have put the memory wire in the wrong place.
Old 05-18-2003, 07:13 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Check your fuses real close I suspect you have a blown fuse causing your problem! Most fuses oiperate more than one circuit.
Tahoe Memory seat issue mac10334 Tahoe 0 03-25-2010 01:08 PM
2004 Sonata Radio...FM stations not working r1bourg Sonata 0 03-31-2009 12:45 PM
Dash and radio looses power. 2003 GrandamGT markymark30309 Grand AM 13 12-05-2008 03:07 PM
radio time & date Jackie Morris Grand Cherokee | Grand Cherokee SRT8 1 07-06-2006 10:33 PM
Radio looses station/date memory darrahfc Engineering/ Technical 5 07-02-2004 03:55 PM
