Old 09-22-2006, 09:49 AM
edsel edsel is offline
brake question
recently acquired a 1990 taurus, 74000 miles on the car. the brakes appeared good however after a week of driving the vehicle, the brakes have gone bad. when i step on the brake pedal it travels almost to the floor before any braking occurs. it will not pump up, however when the engine is off the brakes pump up and their appears to have brakes. when the ignition is turned on the brake pedal goes down and i am unable to pump them back up. i also hear air(at the pedal) as i pump up the brakes with the engine on. any help in diagnosing this will help. i am going to bleed the brakes this morning to see if it is air in the lines. thanks edsel....
Old 09-22-2006, 10:03 AM
semore24 semore24 is offline
Re: brake question
Hi there, I would like to start by saying that I am not a mechnic by any means. But do the work on my cars my self. But I had a Olds cuttless back in the 90s and had some thing very close to what your experiance and it was the master cyclinder. A easy fix on the olds. But dont know on the taurus. I wont know untill I have to fix it.
Good luck
Old 09-22-2006, 10:45 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: brake question
Keep an eye on your fluid, sound like there may be a leak somewhere. Given the miles on the vehicle, sounds like it may have been sitting for a while and either a caliper piston seal or rear drum wheel cylinder may have dried up and is leaking.
Old 09-22-2006, 11:07 AM
Re: brake question
when i got the car last week i checked and filled up the brake fluid. it has remained filled since even with me pumping the brakes. funny checking the trunk i noticed several bottles of brake fluid making me suspicious at the time, however there does not appear to be any fluid loss?
Old 09-22-2006, 11:12 AM
wrightz28's Avatar
Re: brake question
Yeah, several bottles is not a good sign
If it's holding, then maybe jsut try completely flushing out the system and getting fresh fluid in it. I'm still sticking to my guns about a dried up seal possibility tho. Sometimes it takes the right stiuation for the fluid to begin to seep out.
Old 09-22-2006, 11:19 AM
Re: brake question
your probably right but it is funny because the brakes hold when i pump them up with the engine off. when i turn on the engine the brakes go down?
Old 09-22-2006, 11:41 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: brake question
The brakes will pump up with the engine not running because you do not have to overcome the vacuum assist. When the engine is running, the vacuum makes the pedal a lot easier to push down. I agree with a master cylinder, but also check inside the power booster to see if there is any fluid in there. If fluid is inside the booster, replace booster also.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-22-2006, 02:13 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: brake question
And judging by the age of the car, if you replace the master cylinder (and possibly brake booster) you really should flush the entire braking system.
If your Taurus has anti-lock brakes (ABS) then you will want to make sure you get fresh fluid circulated through the ABS pump as well before the valves corrode and prevent the ABS pump from working.
-Rod
Old 09-23-2006, 08:27 PM
Re: brake question
replaced master cylinder and i'm rolling!!! thanks.....
