Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-22-2006, 09:38 AM
LT-Z71drvr LT-Z71drvr is offline
neon doesnt want to shift right away
my 95 neon will shift from 1st to 2nd good but takes a long time to shift from 2nd right when i start when cold
1996 K2500 Reg Cab Long Box
5.7 Vortec, HD 5-speed manual (NV4500)
LT265/75R16E Toyo Open Country M/T
Hypertech Power Programming (AWESOME)
K&N Air Filter, Flowmaster Exhaust
Centerforce Dual Friction Clutch
Pioneer Head Unit, MTX 200 Watt Amp, MTX 10" Thunder 4500 sub
"To be old and wise you must first be young and stupid"
Old 09-22-2006, 10:42 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: neon doesnt want to shift right away
Check your fluid level and add only Mopar ATF+4 to it if needed. You may also want to look into adjusting your kickdown band.
2003 Dodge SRT-4
Old 09-26-2006, 08:14 AM
figured out what was wrong, it was way over full of fluid
whoever had the car b4 me over filled it
coulda done some damage but i think i caught it soon enough
thanks for the advice
Old 09-26-2006, 08:26 AM
Too much fluid isn't a good thing. Did the fluid smell burnt any?
2003 Dodge SRT-4
Old 09-28-2006, 10:46 AM
no, it wasnt, seems to be shifting better now
thanks again
Old 10-22-2006, 07:11 PM
bafflel bafflel is offline
I have the same problem.. levels are ok,, type of fluid in trans is ??? Also when I step on the gas peddle it gets hard about 1/2 way down, if I really press hard like to pass it jumps out of drive.. I disconnected the kickdown cable at the throttle base and now the gas peddle works fine.. would this damage the transmission? still have the cold shifting problem.
