Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani > Performance/Technical
Old 09-21-2006, 09:39 PM
cutthroat1117 cutthroat1117 is offline
Send a message via AIM to cutthroat1117
Engine Bore
I'll be attending UTI in the coming spring, and I plan to do alot with this car with the stock engine, but Im going to stay away from that psychotic hemi idea i had...
I want to go overbore, but i havent heard much at ALL about that. I mean, the tibs got a REALLY good engine, just lackluster performance because of various bottlenecks.
All-aluminum block & head, if i recall, 9.5:1 compression, Steel connection rods... (correct me if im wrong here, lol)
Hell, at this point, I wanna know if anyones bored out their engine 'cus I wanna bore mine out to a 3.0L, slap some 11:1 compression pistons in there, Prolly high-flow injectors, pulleys, Inevitably swap out the tranny for a 6-speed (Likely to be manual)... But im still doing my side exhaust! lol
I went on a tangent there.... All im asking is "Is it possible to bore out the stock 2.7 to a 3.0 without having to put sleeves in it?"
Old 09-24-2006, 09:54 PM
indafastln's Avatar
indafastln indafastln is offline
Send a message via AIM to indafastln Send a message via MSN to indafastln Send a message via Yahoo to indafastln
Re: Engine Bore
Delta DOHC V6
Materials: Aluminum block / aluminum cylinder head
Displacement (cc): 2.7 liters (2656cc/162 cubic inches)
Bore x Stroke (mm): 86.7mm x 75.0mm (3.413 inches x 2.954 inches)
Compression Ratio: 10.0:1
the "delta" 2.7 is a reworked 2.5 (which is why you see the 2.5 and 2.7 castings on the block).
i pretty sure they both bored and stroked the 2.5 a little bit to get the 2.7, but i can't find where i originally read that.
as you can see, those cylinders are pretty close together (at least i think so). i know there are 2 different lower-compression piston kits avail that require a .017-.020 bore for proper fitment, so there has to be at least that much material left to work with.
from what i've read (on another site by a reputable tuner), the stock rods are good to at least 400hp.
Old 09-26-2006, 04:39 PM
Re: Engine Bore
excellent! Thanks for the info! I've been looking EVERYWHERE for detailed engine specs for it...
Old 03-30-2007, 07:01 AM
cars.comn cars.comn is offline
Re: Engine Bore
is there any real differebce with the tiburon and the tuscani
Old 06-20-2009, 01:43 AM
mbradley2020 mbradley2020 is offline
Re: Engine Bore
just a name they are only called tiburons in america and the 2.7 is a bored out 2.5 so no more boring there if you want power then boost boost boost
Old 02-04-2010, 12:33 AM
Johnbbaddest Johnbbaddest is offline
Finding an avatar maker
Hey guys i just joined this forum and I'm looking around for a good avatar maker so i can get a picture by my name. i came across this article: Make your own avatar but it doesn't really help the kind of avatar maker im looking for. I'm looking for one to make for use on forums like this one. If anyone has some good suggestions for me that would be great... Thanks!
- John.
Old 05-23-2010, 10:56 PM
promo123 promo123 is offline
Re: Engine Bore
you're stupid.
the G6BA is a SMALL engine, the tiburon platform is horrible, its FWD, it's Hyundai's FIRST attempt at a "sports" car, and their second attempt was slightly more refined (Genesis)
The 2.7L is a bored 2.5L, boring it anymore would mean hitting the veins rendering the engine useless.
You can wetsleve it to 2.9 or 3.0 but it's a stupid idea, boost the G6BA and be happy, it handles 300 easy without any issues, more than that and you'll want to re-ring the pistons to prevent them from locking under high temp applications (aka boosting)
