Old 09-21-2006, 07:57 PM
Aftershock_024 Aftershock_024 is offline
Premimum Fuel
In the GTP with the 3800 supercharged engine do you need premium fuel? My bro has a 2000 bonne with the 3800 supercharged engine and he for a couple months used just the regular fuel and has been fine. So what do you use in your GTP?
Old 09-21-2006, 07:59 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Premimum Fuel
Yes, premium only. 91 octane or better.
Timeslip 08/12/06
AF Community Guidelines
Old 09-21-2006, 08:11 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Premimum Fuel
You get to low octane and it'll knock & ping.
1999 Grand Am SS 3.4 OHV
Old 09-21-2006, 08:19 PM
bmwgolfguy bmwgolfguy is offline
Re: Premimum Fuel
You are wasting your money unless your engine pings or you have a noticable difference in perfomance. You will know if you do.
Old 09-21-2006, 08:46 PM
BNaylor's Avatar
Re: Premimum Fuel
Timeout.
GM specifies premium on any L67 GM car for a reason. When boost kicks in on a L67 you may not hear any pinging but the knock retard (KR) is definitely in. I've tested using Autotap and the KR will get as high as 10 degrees on regular unleaded.
Plus 1/4 mile times are terrible running on regular.
Good way to destroy your engine over a period of time.
Timeslip 08/12/06
Old 09-21-2006, 11:50 PM
mike561 mike561 is offline
Re: Premimum Fuel
I just run on the premium stuff, ive had WAYYY too many other problems with this car then to risk running into many more problems in the future. BUT correct me if im wrong, i herd if you remove the supercharger belt you can put in lower octane, but of course will notice a huge difference in pickup.
2006 Chevy Cobalt LS
Old 09-22-2006, 02:47 AM
04GTP-WhatLAG?'s Avatar
04GTP-WhatLAG? 04GTP-WhatLAG? is offline
Re: Premimum Fuel
with the L32s you don't HAVE to run 91 or higher(even the manual says you can run 87 with the s/c, but it "recommendnes" 91 or higher) and if you have a performance oriented mind, well, you'll want too... now once you get a reprogrammed PCM, 91 or higher only, though I believe the L67s are supposed to run 91 or higher from the factory...
2004 Pontiac Grand Prix GTP
Custom K&N Fenderwell Intake , 180° thermostat, 3" Down Pipe, High Flow Cat, DHP 1.0 PCM, 3.5" pulley, 1.9 Ratio Roller Rockers, 90# LS6 Valve Springs, AL104s, ZZP Motor Mounts, 17" American Eagle 192s, Magnaflow tips.
not just babies whine
Old 09-22-2006, 07:09 AM
Re: Premimum Fuel
Alright Thanks for the replies. When I get my GTP I'm not to worried about the preformance cause I won't be racing. I still want to have some fun with it but I'm sure even with running regular fuel it will be better than my little cavi with a 2.2. The reason I want the GTP the most is the HUD and heated leather seats. And I wanted the supercharger to but I'm not to worried bout like 1/4 times and all that. Also, I guess we have a 1000 barrel of gas on our property. We usually put 89 octane in it. Will that work ok with out a significant preformance difference?
Old 09-22-2006, 07:57 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Premimum Fuel
My 99 GT has all that, leather, hud, moonroof, etc... so you don't have to get a GTP for those options. I would advise strongly against running low octane, as you'll be tempted to goose it, and knock can do evil things to a motor over time as bnaylor stated earlier.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-22-2006, 08:16 AM
BNaylor's Avatar
Re: Premimum Fuel
For the '97 - '03 L67 GTPs the owner's manual states:
If you have the 3800 supercharged V6 engine Vin Code "1", use premium unleaded gasoline rated at 91 octane or higher.
With the 3800 supercharged engine, in an emergency, you may be able to use a lower octane --as low as 87 --if heavy knocking does not occur.
Lets get our facts straight.
Timeslip 08/12/06
Old 09-22-2006, 10:33 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Re: Premimum Fuel
97 GPGT Non-supercharged. To add to Rich's comment, I have a GT with heated seat, hud. These options just don't come with GTP's
Old 09-22-2006, 01:33 PM
Re: Premimum Fuel
really? i did not know that
Old 09-22-2006, 04:11 PM
Re: Premimum Fuel
Ok, I guess I ahve never seen a GT with HUD. Hope I come across one ! Anyways I do know quite a bit about cars and combustion engines ..... Dont know much about disels.... But waht exactually is *knocking*?
Old 09-22-2006, 04:40 PM
BNaylor's Avatar
Re: Premimum Fuel
Knocking (also called pinging). Technically detonation. In internal combustion engines occurs when fuel/air mixture in the cylinder has been ignited by the spark plug and the smooth burning is interrupted by the unburned mixture in the combustion chamber exploding before the flame front can reach it. Combusting stops suddenly, because of the explosion, before the optimum moment of the four-stroke cycle. The resulting shockwave reverberates in the combustion chamber and pressures increase catastrophically, creating a characteristic metallic "pinging" or "knocking" sound.
Typically caused by low grade/quality fuel or even a mechanical malfunction.
Detonation
The fuel/air mixture is normally ignited slightly before the point of maximum compression to allow a small time for the flame-front of the burning fuel to expand throughout the mixture so that maximum pressure occurs at the optimum point. The flame-front moves at roughly 33.5 m/second (110 feet/second) during normal combustion. It is only when the remaining unburned mixture is heated and pressurized by the advancing flame front for a certain length of time that the detonation occurs. It is caused by an instantaneous ignition of the remaining fuel/air mixture in the form of an explosion. The cylinder pressure rises dramatically beyond design limits. If allowed to persist detonation will damage or destroy engine parts.
Timeslip 08/12/06
Old 09-22-2006, 07:42 PM
phaelax phaelax is offline
Re: Premimum Fuel
I put nothing less than 93 in my gtp, and preferably only from shell or sunoco. I tried BP 92 once, car kept stalling under hard acceleration. My friend put BP gas in his 73 Duster once, that was fun trying to start.
