Changing spark plugs - 96 T&C
Ok, I am pretty sure I can rotate the altnertator back to get to spark plug #1, however, anyone have any suggestions on how to get to plugs #2 & #3behind the engine? Not sure I can get to them from the bottom. If I can't do I have to remove the windshield wiper assembly? Any suggestions will be appreciated.
Thanks, Greg |
Re: Changing spark plugs - 96 T&C
I've only done the rear plugs from below, with the front end up on ramps. It takes some creativity with swivels, extensions, and your hand/arm in some tight conditions. You will also need an 8-10" piece of hose that fits the plugs ceramic insulator to make installation of the plug into the head threads easy.
Others loosen/remove the alternator and get all 3 plugs from above with out removing anything else. I've never tried that method, so I can't comment. You probably have to remove the serpentine belt to deal with the alternator, which adds work time to the project. Be careful removing the plug wires as you can break the core, which will cause missing. There is a plier type tool that removes plug boot/connections easily. If your changing wires too, I would change a plug, then it's wire, until I was done. Watch for binding/touching wires around the rear head, behind the alternator. Always use copper anti-seize on all plug threads. It keeps them from galling/welding themselves to the head. Di-electric grease in all the boots keeps moisture out and aids future removal. I use NKG platinums and like them best for replacement plugs on the 3.3/3.8. Others use Autolite or Champion Platinums. Make sure you get double platinum plugs. Copper plugs work too, just not as long. So...thats why I use platinums because this job isn't too much fun. Plug gap is critical, be sure to set it to factory specs for your engine. |
you're quite correct...
www.autozone.com enter year make model engine, click on repair info on the left then click on vehicle repair guides i'll cut-n-paste just to confirm: Quote:
Windshield Wiper Motor Chrysler Caravan/Voyager/Town and Country 1996-1999 ![]() GL! now I know why they charge more for transverse FWD engines in these things! it's much easier on my dad's caravan-powered chrysler lebaron GTC... |
96 GC 3.8 ltr. I removed the left rear plug by rotating the alternator. I removed the two remaining rear plugs from underneath. There is a wide channel the exhaust runs through. Reach through that channel. It's far from easy but, very doable. Used nothing but a 3/8 ratchet, plug socket and a 3 inch extention.
I wasted an hour removing and reinstalling the wiper tray. It didn't help me at all. I don't think the brand of plug matters as much as making sure you install platinum plugs. Platinum is why you don't have to change these but every 100K miles. BTW - when I replaced the original Champions at 116k miles, they looked like they could have gone another 116k miles. Have Autolites in it now only because my supplier was out of Champions at the time. Still going strong at 190K miles. MPG hasn't changed since drove it off the lot. That was 11 years ago next month. GregB - First good luck. Second is there any chance you could delete your repeat post? |
Everyone, thank you for the pointers and information. RIP, you asked me to remove my repeat post. I will be glad to, however, I am not sure how to. Can you tell me how?
Thanks again, Greg |
Here's the sequence to delete: edit/delete/delete message/delete this message. You'll see the buttons as you go. Not sure but at the end you may see a "are you sure" button. Cheers!
