speedometer help
I own a 91 camaro rs, the speedometer is electrical. recently my speedometer has had to warm up before it worked, so i would drive 10 miles and then it would start working. then it would suddenly stop working totally, we changed the speed sensor and, it didnt seem to help and now i cant think of any thing else besides the computer, if you can help please do so, i have no clue how fast im going and my overdrive wont work. thanks
Re: speedometer help
dont know if these are like caprices at al, but it may be a bad connection on the back
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
I was reading about performance chipping and learned that the speed governor and rev limiter were all vital, if the wrong part went the speedo wouldn't work and the computer or transmission wouldn't know what speed you were going. So it may be something in or around the computer.
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
I don't think that the speedometer and overdrive are related, mainly because the computer doesn't control the 700r4. I guessing there is a loose connection somewhere between the VSS and the speedo, because it's not completely dead. Maybe check all the wires and see if everything this how it should be, look for a eaten through wire or a connection that's little bit loose. When the guage doesn't work does the needle drop and not move at all, or does it kind of hover or shake a little?
![]() '91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect... |
the computer does control lock up though. Which it bases off of the vss. The computer doesnt do anything with the speedo though. Not directly anyways.....i dont think......Did you match your vin to get the right vss for your car? I would also check the grounds for your cluster. Grounds and connections in general.
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
