I got a 97 Dohc neon and it randomly stalls, it been doing this for months
now. After doing the key dance it spitout the useless code 12. I took it to the dealer and they said they could not find anything wrong with it. A week later it stalled again and this time it would not restart, so i had it towed to a firestone shop. They told me the fuse for the fuel injectors was blow and now it runs again, however they do not know why it blew(it could all be BS). Iv got a bad feeling that when i get the car back it will do it again. NOTE: when the car stalls it lights up the oil light, i always check the oil, its fine (check engine light do's not come on) i checked the wiring of the battery, it's fine do's the alternator have its own ground wire?or is it mount act like gound ![]() when the car dos run it runs great Thank you for all the help, Dan P.S. I dont want to replace stuff unless i know for sure that it's broke |
Re: 97 neon dies randomly code 12
hmm, fuel injector circuit shoulda point out to code # 27...
code #12 -> your battery ws disconnected recently? did you go anywhere near the terminals w/ a tool & possibly created a short to blow the fuse? if everything's running ok, i'd suggest going to your local autozone & do the free OBDII scan instead, just to see a more pinpointed trouble code as seen on the following list: http://www.troublecodes.net/chrysler...20253335.shtml if nothing's wrong, @ least you'll know where to go next time :P |
once in a while after it stalls and wont restart i disconnect the negitive battery terminal to get the car to restart
autozone told me the scanning tool will only pull a code if the check engine light is on, of course i did'nt listen and went ahead and tried the scanning tool to no avail, no codes found Thank for your reply |
Check all your grounds and clean all your connections to the battery, starter, and alternator.
2003 Dodge SRT-4 |
I got a ground wire that is connected in the hood area above the pasanger tire but its not connected to anything!!!! can anyone tell me where it connects to????? dos it go down and ground the alternator?
