Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 09-21-2006, 03:09 PM
19RaVeN96 19RaVeN96 is offline
Exclamation Changing turn signal light?
My friend has a 99 civic and the driver's side front turn signal light went out. How do I replace the bulb? Usually cars have 2 piece headlights and I pull the corner lens out, but these are 1 piece. Any help? Thanks.
Old 09-21-2006, 09:50 PM
bluevp00's Avatar
bluevp00 bluevp00 is offline
Re: Changing turn signal light?
You need a flathead screwdriver.
Turn the steering wheel all the way to the left, and using the screwdriver pop open 2 or 3 small plastic 'rivets' in the wheel well by prying on the center circular part.
Push back the wheelwell enough so that you can reach the turn signal bulb socket. Turn the socket, pull it out, and remove the bulb.
Installation is reverse of removal.
