Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-21-2006, 01:37 PM
sroney sroney is offline
Struts
Can anyone tell me how difficult it is to replace the struts on a 2000LS?
With ~125K they feel a little soft.
Thanks!
Old 09-21-2006, 03:47 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Struts
The front struts require a spring compressor to remove the upper mount and would best be left to a garage if you don't have the proper tools. Those springs are under extreme pressure, and could cause serious injury. The car will also require a 4-wheel alignment when you're done.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-22-2006, 04:19 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Struts
Actually Rich the complete strut assembly can be removed without applying or using the spring compressor. Once the strut assembly is off the car then you need the compressor to swap out the strut. You can rent the spring compressor or buy your own. Not that expensive.
Strut jobs are done DIY all the time even by the inexperienced but I agree it is less of a hassle to have a shop do it for you.
Also, with your mileage you may need other parts replaced such as upper strut mount/load bearing and other rubber bushings/insulators.
Timeslip 08/12/06
AF Community Guidelines
Old 09-23-2006, 10:02 AM
richtazz's Avatar
Re: Struts
I guess should have specified the spring compressor is needed after the strut is removed from the car to transfer the spring to the new unit, thanks for the clarification Bob. Monroe is starting to offer a complete , ready to install front strut/spring/mount assembly, too bad they're only available in Sensa-trac's.
Old 09-23-2006, 10:20 PM
57chevyragtop 57chevyragtop is offline
Send a message via MSN to 57chevyragtop
Re: Struts
I am curious why you say "too bad they're only available in Sensa trac's?? Not sure what you mean by that...
In a related recent post on Buick ride, would it be possible to use a softer spring rate to replace that of Impala if you could find size and fit?
Old 09-24-2006, 05:05 PM
richtazz's Avatar
Re: Struts
IMO, Monroe Sensa-Tracs are junk. They give a wallowy ride and have a tendency to make groaning noises. Monroe used to be "THE" aftermarket strut to buy, but I no longer feel that is true. KYB is the best, non-oem strut out there.
Old 09-24-2006, 09:50 PM
Re: Struts
Ok, that a reasonable explanation
