Old 09-21-2006, 01:07 PM
karson karson is offline
Question po171
refilled my radiator with 50/50 antifreez
and now i have a service engine soon light
my code reads po171 [to lean]
can some one plaese let me now what that means
thank you
karson
Old 09-21-2006, 03:51 PM
panzer dragoon panzer dragoon is offline
Re: po171
To provide the best possible combination of driveability, fuel economy, and emission control, a closed loop air and fuel metering system is used. While in closed loop, the PCM monitors the HO2S 1 signal and adjusts fuel delivery based upon the HO2S signal voltage. A change in the fuel delivery will be indicated by changes in the long and short term fuel trim values. The fuel trim values can be monitored with a scan tool. Ideal fuel trim values are approximately 0 percent . If the HO2S signals indicate a lean condition, the PCM will add fuel, resulting in fuel trim values of more than 0 percent . If a rich condition is detected, the fuel trim values will be less than 0 percent , indicating that the PCM is reducing the amount of fuel delivered. If an excessively lean condition is detected, the PCM will set DTC P0171.
Hopefully it was just a bad case of fuel and the code goes away.
Old 09-21-2006, 03:53 PM
maxwedge maxwedge is offline
A990 racer
Question Re: po171
thank you
karson
Welcome to AF. Some info missing, was this a routine coolant change youi did or part of a repair job?
Old 09-21-2006, 07:42 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Re: po171
3.8 or 3.5?
