Old 09-21-2006, 12:58 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
3000gt timing belt change
i have a 98 3000gt sohc and im about to change my timing belt but need instructions on how to do it myself..i have a qualifed person helping me who has done one before on a simular car ( eclipse )..anyone ever done it before or no a web site that gives detailed instructions..i have a cd rom repair manual but didnt specify the sohc motor..any help would be appreciated
Old 09-21-2006, 01:15 PM
3kvr4's Avatar
3kvr4 3kvr4 is offline
Send a message via AIM to 3kvr4
Re: 3000gt timing belt change
Check out our faq
here are some links
http://www.team3s.com/60k.htm
http://www.vr4stealth.com/60k-tune.htm
http://www.team3s.com/~egross/3S/Maint/All/TBelt/index.html
http://www.automotiveforums.com/vbulletin/showthread.php?t=376006
Old 09-21-2006, 02:06 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
all those links describe the timing belt change for a DOHC motor. you have a SOHC motor, so it should be pretty simple since you only have 2 camshafts to deal with.
i've only done timing belt changes on DOHC motors, but it should be the same for all. the basic rundown is this: IF YOUR CAR IS OUT OF TIME: look for timing marks on the cam gears AND the valve covers. you'll need to line up the cam gear marks with the valve cover marks. find the timing mark on the crank pulley and line it up with the timing mark on the block, just behind the pulley. pull the old belt off, put new belt on. make sure all timing marks are lined up. use binder clips to hold the belt in place on the cam gears. set the tensioner, and you're done.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
