Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 09-21-2006, 12:52 PM
brg25 brg25 is offline
1996 Accent - low rpm hesitation
As I shift gears (5 speed) the car will hesitate/buck as I accelerate until RPM's reach a certain point. At highway speed (high rpm) the car runs fine. I'm not sure if the problem is fuel or spark. It seems to occur more after the car warms up. Any ideas?
This past year I have replaced:
Fuel filter (more than once)
Idle air control valve
Crankshaft Position Sensor
Ignition coil
Plugs and wires
Alternator
Starter
Old 10-20-2006, 12:51 PM
joe45 joe45 is offline
Re: 1996 Accent - low rpm hesitation
Did you get your can fixed? Mine does the same thing.
Old 10-22-2006, 06:31 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
what plugs did you guys put in the car?
Old 10-24-2006, 08:52 AM
Nope, problem still exists although it hasn't gotten any worse. Would dirty fuel injectors cause this problem?
I have NGK plugs right now. It's actually been over a year and I'm going to change plugs, wires and fuel filter again just for good measure.
Old 10-26-2006, 07:58 PM
I'm going to try a compression test this weekend. Maybe that will tell me something. I had a guy look at my plugs and he said they looked OK maybe a little lean.
Old 11-01-2006, 10:42 AM
Problem fixed
Check engine light finally came on and I read the code. Cylinder 2 misfire. New plugs and wires fixed the problem.
Old 11-06-2006, 05:56 PM
Re: Problem fixed
I did that too but it started doing it again.
