Need Help With Firing order on 98 Buick Skylark 3.1
I need help with a firing order on a 3.1 i know it is 1 2 3 4 5 6 but how do i run the wires
Re: Need Help With Firing order on 98 Buick Skylark 3.1
The problem i am having is the coil is numbered 5 2 6 3 4 1 i belive so this is my problem if the firing order is 1 2 3 4 5 6 then how do i connect the wires
The cylinders are numbered as follows, starting at the passenger side/ serpentine drive belt end of the engine:
Rear bank: 1-3-5 front bank: 2-4-6 Run the wires from the number on the coil pack to the corresponding cylinder number above. Example, the wire on the coil tower with the number 5, should go to the rear bank cylinder on the driver's side (cyl #5). The wire connected to the coil tower with the #2, should go to the front cylinder, passenger side and so on.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Thank You we will try that!
