Old 09-21-2006, 11:34 AM
DavidLang's Avatar
DavidLang DavidLang is offline
Thumbs up Window Hop Cured!
Every time I tried to roll the window up or down it would stick and stress as I coaxed it into place. I shot WD-40 into the channel on both ends and now it works like a champ. If it moves and it's not supposed to, use Duct Tape. If it doesn't move and it's supposed to, use WD-40!
Old 09-22-2006, 05:31 PM
MoJoWrrrrKen MoJoWrrrrKen is offline
Re: Window Hop Cured!
Thanks, I think I'm going to try that.
Just to clarify what you did :
1. Roll the window down all the way,
2. Shove the little plastic spray extension into the tip of your WD-40 sprayer,
3. Spray down into the window slot. (Concentrate on the leading -- front -- and trailing -- back -- edges of the window.
4. Run the window up and down a few times, to distribute the WD-40, and wipe up any over-spray on the window.
(Personally, I probably would have guessed that the linkage that does the job would be somewhere behind the crank, but maybe all that would do is get more glop on the glass.)
Old 09-24-2006, 06:18 PM
DavidLang's Avatar
Yes, that is correct. I too thought it would be more of a linkage problem but as it worked out just a shot of good ol' WD40 on both ends of the window molding took care of it.
Old 01-17-2007, 01:54 PM
mostly_water mostly_water is offline
This trick has worked wonders for me too over the months, but I've noticed recently that the rubber weather-stripping that the window glass slides in is either warped or deteriorating. It's especially noticeable along the edge toward the front of the car. Is replacing this a do-it-yourself task, or a drop-off-at-the-shop task?
Thanks.
Old 01-17-2007, 05:03 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Silicone Spray (any automotive store) works well also.
Even some Parowax (wax) will help.
How about some Talcum Powder? Dry.....
Any oil will collect dirt which booger's up the works.....
WD-40 tends to completely evaporate in a short time.
Just some observations and my $ 0.02 (in U$D). No idea in Canadian....
DoctorBill
Old 01-18-2007, 03:46 AM
91Caprice9c1 91Caprice9c1 is offline
The cause of this problem in these cars in the first place is the weather stripping which starts at the bottom of either window track, around the top of the door/window frame and back down to the bottom of the other window track in one piece. A do-it-yourselfer should have a good time doin' it. Door panel removal, and glass removal is nessecary, but after the glass is out it's a simple task to replace the weather stripping, and all in all it's not too bad. Wear long sleeves, or your forearms will hate life. The only trouble is - I haven't been able to find replacement weatherstripping anywhere. I've had to use stripping from wrecked geos in our fleet.
-mechanicmatt
