Old 09-21-2006, 03:22 AM
amtech4 amtech4 is offline
Just plain wierd
Here's the full situation. A couple of months ago my cat conv. became plugged and was subsequently replaced. Less than 2 weeks after replacing it, I got a check engine light and the engine started to run hard. I scanned it and got a #5 cylinder misfire. Okay, no problem. I checked the wire- it was good. I pulled the plug- some carbon build up so I replaced it. I cleared codes and started the vehicle and got the engine light again with a rough engine. Scanned it- #6 cylinder misfire. Checked wire- it was good. Checked plug- it was good. Resaeted all connections and cleared codes. Started vehicle and got the same thing. Scanned codes and got a #5 cylinder misfire. Back and forth I went with no joy. In the middle of this I also changed the cap and rotor just to eliminate them. I suspect a bad ignition module, am I right? But wait, there's more. Now, when I turn the ignition to on, I get minimal voltage read from the battery (fully charged off the charger) and after the vehicle starts running, for the first 5 seconds or so there are absolutely no indications on the gauge cluster and no interior lights. All the sudden everything comes online with all gauges functional. I suspect a bad ECM or BCM, am I right? Please help, I don't feel like paying a mechanic for something I can do myself.
I am working with a 98 Blazer with a V6 Vortec.
Old 09-29-2006, 04:35 PM
vtwindave vtwindave is offline
Re: Just plain wierd
try checking your ground wire and positive wire coming off the battery or junction box, also see if you have any fuseable links that may be corroded or loose connections.
