Old 09-21-2006, 01:01 AM
camelman55117 camelman55117 is offline
'92 PAU Alternator
The battery feed connector on the alternator broke off at about 1/4 inch. It still holds the wire on but probably not for long. Can the connector be replaced or will I need to get a new alternator? The alternator works fine(14v) and I hate to buy a new one if it's not needed. Thanks for any words of wisdom.
Old 09-22-2006, 09:44 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: '92 PAU Alternator
You might try an alternator/starter repair shop in your area. Usually they keep some in stock and might even install it for you for a few bucks.
Old 09-22-2006, 12:57 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Is this your original Delcotron CS130 or CS144 alternator?
Because if it is then it is a keeper and I agree with Bo that you should get the connector repaired by an automotive electrical shop.
The aftermarkets leave a lot to be desired and the GM OEM are expensive.
Timeslip 08/12/06
AF Community Guidelines
