Old 09-20-2006, 08:52 PM
jimarch40 jimarch40 is offline
Both Turn Signal Dash Indicator Light On
I have 96 GMC S-15 Jimmy and when I turn the headlights on, both turn signal indicator lights on the dash come on. I've checked all outside headlights, turn signal, license plate lamp and tail lights thinking something might be burnt out but everything is working fine. Any ideas?
Old 10-22-2007, 09:35 PM
cccfabioccc cccfabioccc is offline
Re: Both Turn Signal Dash Indicator Light On
This post is from 06! i have the same exact problem. maybe i have this guys old car. does anyone have any ideas?
Old 10-23-2007, 10:29 PM
I still have the Jimmy and the turn lights are still coming on when I turn on the headlights. I guess I've just learned to live with it since nobody had any thoughts on what it might be.
Old 10-27-2007, 01:01 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
This could be a multifunction switch problem. Have you had any other issues? Your Hazzard light button, try moving it little from side to side is there any play?
Old 10-27-2007, 09:11 AM
I think you might be on to something. If I have the lights on and then turn on the hazzard lights, obviously they blink but then when I push the button down to turn them off, right before it clicks both of the lights are off and not blinking. Then once it clicks into the off positiion then they come back on. So there might just be enough play in that switch that is causing it to make contact.
Old 10-27-2007, 06:27 PM
blazes9395's Avatar
Newbie mod
Those switches can be replaced instead of the whole assembly. I have to find the article that was on here about that, it could be in the tech section of this forum. The actual switch can just be replaced and can fix this problem.
Old 10-27-2007, 06:30 PM
blazes9395's Avatar
Newbie mod
her eit is....
http://www.automotiveforums.com/vbul...d.php?t=595263
