Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-20-2006, 07:39 PM
[email protected] walkerl@wfu.edu is offline
Starter from hell!
Guys I need your help, I cannot remove the starter from my 1999 4runner 4cyl 2wd. I got i jacked up in front, on jack stands, driver side tire removed. I tried from the top, the side, and the bottom, and can not find the 2nd bolt. I can see the first bolt. I really need some tips or direction, I've read every thing in the faq, but none really help with removing the starter
Old 09-20-2006, 08:50 PM
rhandwor rhandwor is offline
Re: Starter from hell!
Look for a stud with a nut some units are installed this way. Use a short 3/8 inch extension just a little longer than the starter. If you found the bottom bolt the other bolt should be on top of the starter run your hand around the starter and feel. Once you feel it put the socket on it and loosen. With the extension the ratchet is back of the starter. Otherwise you need a curved wrench.
Old 09-21-2006, 12:04 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
From the 2003 Tacoma FSM in the sticky post at the top of this forum
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-23-2006, 12:56 PM
Thank you guys for all of your help, i got the starter off, rebuilt, and put back on today,
Thanks again.
P.S. It is a lot easier to put on then get off
