Go Back   Automotive Forums Car Chat > Eagle > Summit
Old 09-20-2006, 01:59 PM
MooseNelson's Avatar
MooseNelson MooseNelson is offline
Removing Eagle '92 front rotors
This Eagle I bought is in need of serious brake job, replacing rotors front and back.
Finally got the right socket for axel nut 32mm, but I'm stuck getting off the plate that's in front of the rotor. I assume it's just stuck on there and in need of a serious whacking, but any help here? see pics:
Old 10-03-2006, 08:52 AM
Knifeblade Knifeblade is offline
Re: Removing Eagle '92 front rotors
Whack it off. But, not too forcefully. Use a prybar or piece of wood between rotor and hub face, and tap alla round, should free itself.
But, since I never worked on the system U pic.'ed, I'd be very careful, there may be a bearing involved.
let me know if it a talon, vision, etc. I may have a link that might help ya out
Old 10-10-2006, 02:18 AM
thanks for the reply
this is an 1992 summit hatchback 1.5l
I tried again another day and I think I got the hub further off, but no luck.
I'm going to rent a puller from autozone and try that, I was reading a manual at the library, saying "do not pry or bang" the hub off, use special "chrysler" tool
g
Old 10-26-2006, 09:41 PM
the solution to this problem can be found here:
http://www.automotiveforums.com/vbul...d.php?t=636319
