Old 09-20-2006, 01:20 PM
greenmachine1 greenmachine1 is offline
Best Brakes & Strut replacement parts
Hello,
I have a 94 GT3000 SL.
I would like to get recommendations for the best brake pads, rotors and front struts for replacing these stock parts with similar.
Recommendations can be for both - purchase online or at a chain store.
Thanks in advance,
Mark
Old 09-20-2006, 01:37 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Best Brakes & Strut replacement parts
If you want stock replacements go with Raybestos PG Plus rotors and Raybestos Quiet Stop pads. They stop pretty damn good, they are quiet, and they don't dust nearly as bad.
As for the stock replacement dampers, I wouldn't waste the money. I would get some descent street performance dampers instead.
Old 09-20-2006, 02:10 PM
2old 2old is offline
Staying away from specific brands (because everyone has their favorites for different reasons)...
For street driving I would suggest ceramic (includes carbon-metallic) pads and non-slotted, non-crossdrilled rotors. The combination will have low dust, last a long time and be a lot better then stock.
For racing you are looking at metalic pads with slotted rotors but they are petty much horrid on the street: squeals like a dying pig, dusts like you are looking for figureprints, but slows you down like you your car is tied to a anchor.
If you are looking at a brake upgrade, look into SS brake lines... It's the biggest bank for the buck performance upgrade.
I agree with Polygon... ECS really is a gimmick compared with modern performance dampeners...
Old 09-20-2006, 02:55 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
for dampners/struts, the KYB GR-2 gas strut is a good choice, and considerably cheaper than the OE stock replacements. i think also Monroe makes a strut for our cars.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-20-2006, 03:10 PM
Linebckr49's Avatar
for the KYB struts, www.3sx.com has pretty good prices on them. since your SL has ECS, make sure to choose that option.
also, i would recommend www.thepartsbin.com since they sell very good quality OEM parts AND some aftermarket parts. the great thing about this site is that they will give you FREE SHIPPING on orders over $50. i've bought from them several times. good stuff.
93 3000GT base
Old 09-20-2006, 03:18 PM
AutostradaVR4 AutostradaVR4 is offline
i recommend you read this as well.
http://www.stealth316.com/2-brakeupgrade.htm
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 09-20-2006, 09:01 PM
sLADe781 sLADe781 is offline
http://www.summitracing.com/ has awesome prices too. That's where I got my GR-2s from.
