Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-20-2006, 10:34 AM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
boost controller help
I just upgraded trubos from stock to a 14b. the turbo is working fine. but what I need to know is where do I get the pressure source to run my boost controller? with the stock turbo it was easy the pressure source was right on the turbo. the only thing i can think of is to run it from the b.o.v. line but that not a good idea. the j-pipe i got was from dejon tool. thanks
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 09-20-2006, 12:30 PM
steviek's Avatar
steviek steviek is offline
Re: boost controller help
you can tap into the j pipe if you want. Or you CAN run it from the BOV but it isnt the best cause boost spike since its so far from the turbo.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 09-20-2006, 01:33 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Tap the J pipe, or tap the lower intercooler pipe.
DO NOT tap the bov line. I originally had my mbc hooked up like that, but I kept loosing boost early. Now, it holds rock steady at 15psi. Plus, I now get around 10psi in 1st gear when I only used to get around 1-3 psi. Much better boost control.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 09-20-2006, 06:45 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
woot. People are listening to what I've been bitching about for so long now!
now - 2000 civic
soon - 2002 is300
Old 09-20-2006, 08:31 PM
do you think this would fit with the dejon piping I have?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
1997 Eclipse GS-T
Old 09-21-2006, 11:36 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
wait, so you dont need to use a vacum? ok i have mine taped into the BOV and i lose boost really fast to. i can use the pressure line off the turbo you say (stock T25) because i just plugged that, so i could use that as a positive pressure source the the boost controler, then straight to the wastegate??? right?
Old 09-21-2006, 11:57 AM
I'm confused on what you're asking. Tap the MBC into your turbo outlet and then the other side to the wastegate. Enjoy stable boost levels.
now - 2000 civic
soon - 2002 is300
Old 09-21-2006, 12:01 PM
Black99GST's Avatar
ok, but can i use the fitting on the stock T25 turbo used in the OEM configurating with the BIS sencor? the line that i sould run the the positive boost source, is the same line i'm running the tap to the BOV,right?
Old 09-21-2006, 12:33 PM
black99gst,what kind of boost controoler do you have?
1997 Eclipse GS-T
Old 09-21-2006, 12:38 PM
Black99GST's Avatar
'99 eclipse GST 5-speed
Short shifter; Apexi N1 3" catback; 3" test pipe; Megan Racing 3" downpipe; K&N FIPK; Type-S; Turbo XS high power boost controller @ 15PSI; Custom FMIC set up with short route pipe; Walbro 255HP; aeromotive AFPR; hand full of other mods...
http://www.cardomain.com/ride/2167683
http://www.ratemydsm.com/member/Gear...ember=GearHead
Not stopping till atleast 400whp
just like it says in my sig. lol a turbo XS hp
Old 09-21-2006, 01:08 PM
oh shit my bad I didnt see it.lol
from the nipple on the compressor housing connects to the b.c. then from the b.c. to the wastegate.
1997 Eclipse GS-T
