Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 09-20-2006, 09:28 AM
carcrazysincebirth carcrazysincebirth is offline
02 Dakota Quab Cab 4X4 - 4X4 problem!
My 02 Dakota wants to pull fairly hard to the right (ditch) after it is put into 4 wheel drive. Then when I try to put it back into 2 wheel drive, it seems like it takes forever before it will make the switch - at least 5 miles. Step by step instructions or clear details would be very much appreciated!
Old 10-15-2006, 08:32 PM
69Charger 69Charger is offline
Send a message via MSN to 69Charger
Re: 02 Dakota Quab Cab 4X4 - 4X4 problem!
Alot of times the front diff doesn't disengage till you stop or back up or lockup the front wheels, this is caused by the angle cut of the gears in the case being backwards allowing it to go into gear easier..
MIne used to pull to the right as well, I'm sure its something to do with alignment but I never cahsed the problem since I was plowing snow with the truck anyways
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
87 Mustang GT, 5.0L 5 spd, MSD ignition, BBK tubes, flowmasters, tri-ax shifter, 4.10 gears
69 Charger SE, stroked & poked 383,727 over 550rwhp
86 Chevy 2500 4x4 Plow truck, 350/TH400, 8ft fisher plow
