Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 09-20-2006, 08:26 AM
jsober61 jsober61 is offline
96 Intrepid/ leaking gas
Hello,
As the title says. I drive a 96 Intrepid that I use for commuting to and from work now. I just started using it a week ago. It has been sitting for awhile. Anyway...It is leaking gas. It leaks when it is running and it is coming from the rear of the car by the gas tank. Is this a fuel pump problem or a torn line perhaps. Keep in mind that this car sat for about sixs months in mothball before I took the paddles to her again.
Jon S.
Old 09-20-2006, 10:51 PM
AWP9521 AWP9521 is offline
Re: 96 Intrepid/ leaking gas
Better check the lines for leakage at the fuel pumps pressure and return line connections and the o-ring seal where the pump goes into the tank (Accessable from in the trunk area, under the trunk liner you will find a fuel pump access plate on the trunk floor behind the rear seat), the fuel Filter (located under the car on the passenger side ahead of the rear wheel} and the lines themself for any cracks. It may also be possible that the o-ring where the filler neck goes into the tank is cracked and leaking, hopefully the plastic tank itself is not cracked.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 09-24-2006, 06:35 PM
wafrederick wafrederick is offline
Banned
Is it a 3.3 or a 3.5?The 3.5 has problems with the fuel rails cracking and injector o rings leaking,the fuel rails are made out of a plastic material and are not cheap,dealer part only
