Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 09-20-2006, 07:43 AM
nrisher1 nrisher1 is offline
abs module
abs and break light is on, there's a fuse under the hood on the right-side 60A abs, i took that fuse out because the abs module was running it would not go off. and that's when those two light came on, if i put the fuse back in, the lights go off, but then the abs module start running again. that wil kill the battery. i got a price of $980.00 from gmc to replace the module. 2001 gmc yukon
Old 09-20-2006, 09:28 AM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: abs module
You need to post a lot more infomation than you did. Some usefull info would be year make model and the exact problem.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 09-20-2006, 09:41 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: abs module
Originally Posted by nrisher1
do anyone know how to fix this?
Like said more info neded.
Tips on getting a good answer to your questions.
People trying to answer your question do not have a crystal ball.
So give them all of the info you have like year make and model and engine and transmission.
Also service cars engine and transmission service history or any recent repairs or problems.
Also a description of your problem and what it is doing or not doing.
If you have codes give up the code no.
And remember a code does not say replace the part but only points to the problem that you have to check out.
So to better help you give up all of the info you have on it.
MT
MT
Old 09-27-2006, 11:57 AM
redcar redcar is offline
Re: abs module
try ebay, there is a guy who will rebuild your abs module for less than $200.00, you may also find him on the internet, hope this helps
Old 09-28-2006, 01:42 PM
Re: abs module
Thanks For The Info
Old 09-28-2006, 01:54 PM
Re: abs module
How Did U Get The Picture Of Your Truck To Show??
Old 10-08-2006, 08:35 PM
WEF WEF is offline
Re: abs module
You have to replace the whole module. I spent about 2 weeks trying to get a reasonable price and got PO'ed and traded the truck for a '05 Yukon. The best price I got was from gmpartdirect.com (I wanted new) and even after installing it myself, the module had to be flashed by the dealer....another $200. If I had intended on keeping the truck, I would have bought the part at my local dealer at discount (most dealers will do that on big items) and had them install it. That way, parts and labor are covered and I wouldn't have wasted so much time.
