Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-20-2006, 04:51 AM
that_guy5's Avatar
that_guy5 that_guy5 is offline
overheating
ok i got a 98 civic and the prob is that it overheats. but the weird thing is that the gauge only goes up when im at a light or in the drive thru and stuff like that and when i accelerate it goes back down to normal i checked the fluid, thermostat, and the fan goes on to i dont know what the hell could be?? was wondering if u guys could help me out b4 taking to a mech and charging me a gang of $$
Old 09-20-2006, 03:16 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: overheating
so the fan w orks and you already replaced the thermostat? try a rad flush
Old 09-22-2006, 02:57 AM
that_guy5's Avatar
Re: overheating
well u could hear the fan turning on and this guy at work told me that if u feel the bottom radiator hose hot the thermostat is working i ll try to do that radiator flush to see how it goes
Old 10-17-2006, 09:20 AM
jsg911 jsg911 is offline
Re: overheating
Fluid is missing in your cooling system . Follow all the steps to fill your system. If it dosn't work , maybe faulty water pump...
Old 10-17-2006, 02:06 PM
somick's Avatar
somick somick is offline
Re: overheating
It could be few different problems, but like it has been said:
1. Check your fluid level.
2. To make sure your thermostat is working your bottom radiator hose should get hot. But I would check it at the theromostat housing side and not at the radiator side. It may get hot from the radiator itself.
3. Your radiator should be heated evenly. Test its temperature throughout the radiator body. BE VERY CAREFUL. The fan my come on even with the iginition off.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
