Old 09-19-2006, 11:17 PM
dwarfy.mafia dwarfy.mafia is offline
Series 1 cold air intake
Hi, I was wondering where I could find a cold air intake (such as k and n) for a series I engine. Everything on ebay is for the series II.
Old 09-21-2006, 04:03 PM
Re: Series 1 cold air intake
bump.. anyone know?
help would really be appreciated
Old 09-21-2006, 04:28 PM
http://cgi.ebay.com/ebaymotors/92-93...QQcmdZViewItem
would that work for the series I?
I have a 93 lesabre
Old 09-21-2006, 06:06 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Maybe, but it would be hard to tell without looking at it in person. Your best bet would be to retrofit your own. You can get a cone K&N filter off ebay fairly easily and suitable pipe at home depot.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 09-21-2006, 09:08 PM
Thx for the help
How would I fit my own?
Would it be as effective as the ones on ebay?
Old 09-22-2006, 12:02 AM
Alibi's Avatar
I've seen them made out of flexible plastic tubing for clothes dryers. The one I use is made out of flexible air ducting elbows (and then wrapped in tape to seal it). As for rubber connections, Autozone sells some that ought to work.
You will need to drill a hole and fit the air temp sensor into the pipe after the filter though or you'll run into trouble. Otherwise, it really isn't hard to do. I've got about $35 invested in mine since I lucked off and found a used K&N on Ebay
As for a cold air induction box, all you really need would be some sheet metal or even plywood. It isn't rocket science, as long as the box keeps the hot engine air from being sucked in by the filter youd should be fine.
The ones on Ebay just look pretty, but as long as you get everything sealed right, it'll be fine.
-Eric
Old 09-22-2006, 01:45 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
I have a 93 lesabre
Yes, that intake is shown equipped to a series 1.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 09-22-2006, 02:27 PM
ya, I saw that as well, but im a little skeptical, because it says 94-and up..
Old 09-22-2006, 07:34 PM
buick24 buick24 is offline
Man thats a pretty good price for the K&N filter itself. Hope everything works out for you well.
