Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 09-19-2006, 11:35 PM   #1
Kortb26
Send a message via AIM to Kortb26
Noise from tires, not brakes??
There is a noise coming from my tires, however its not the brakes...its a loud screeching (sounds like a human moaning or screaming), when my car is rolling, like through a drive through or just moving up at a light is when it makes the noise Any help guys? I'm a 21 year old student that completley got taken advantage of, they charged me $2100 and didnt fix a single thing I complained about...I wanna know so I can walk in there and tell them what they did wrong..Thanks Oh and its a 97 Pathfinder 4x4
Kortb26 is offline   Reply With Quote
Old 09-20-2006, 07:13 AM   #2
lewisnc100
Re: Noise from tires, not brakes??
Its probably not your tires or your brakes. There's a Technical Service Bulletin (TSB) out on this noise and it comes from the baffle plates behind the hub. Should have been easy for them to look that up since it applies to your model year.
I had the same problem, usually starts to make noise once the wheels warm up and the noise does not change much when applying the brakes. The baffle plates run about $20 each, one for each side. Unfortunately you have to remove the hub to swap the new plates in for the old ones, but if you're repacking the bearings anyway its no extra work. Some people just cut the rubber edge off the original baffle plate and that seems to work too.
Here's some of the details in the TSB (97-014A):
If a 1996-98 Pathfinder vehicle exhibits a high pitch squeal or whistle from the front hub/brake area, the cause may be the front hub dust seal. This noise, can be heard while driving next to a wall where the sound is reflected. The noise is also more likely to be heard after several miles with the front wheels at normal operating temperature. A countermeasure front hub baffle plate is available to resolve these incidents. The countermeasure baffle plates are modified to also function as dust seals.
Baffle plate RH 41150-1W400
Baffle plate LH 41160-1W400
1997 Pathfinder XE
Air Lift Air Bags, Warn Hubs
2000 Windstar SEL
lewisnc100 is offline   Reply With Quote
Old 09-20-2006, 09:28 PM   #3
FixUrNissan
FixUrNissan's Avatar
That is Corect , Well said
FixUrNissan is offline   Reply With Quote
