Old 09-19-2006, 12:00 AM
ERIC S ERIC S is offline
99 S10 BLAZER no power with air on?
My wifes blazer runs great with the a/c off ,but it is really sluggish with the a/c on! any idea's? thanks
Old 09-19-2006, 08:57 PM
AJT1961 AJT1961 is offline
Re: 99 S10 BLAZER no power with air on?
You might try posting this in the Blazer forum which seems to be a much more active board. I'll be interested in seeing the replies as I'm having the same exact problem with my 2000 S-10 Blazer 4wd. Since it's overdue for new plugs/cap/rotor/fuel filter, I am planning to tackle that first to see if it solves the problem before digging deeper.
Old 09-19-2006, 10:27 PM
THANKS AJT1961! I did the tune up and gained 2mpg but it didnt help the a/c problem..
Old 09-19-2006, 10:30 PM
My wifes blazer runs great with the air off but is really sluggish with the a/c on!any idea's thanks..
Old 09-19-2006, 10:35 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
pretty normal, the a/c clutch is engaging and it really puts a lot of drag on the engine. If it is really bad, it could be a sign of the clutch going bad too. If you notice a bigger drag than usual, and if you did a tune up, and the engine is running good, take a close look at the compressor.
Old 09-20-2006, 02:16 AM
I have the same noticeable and seemingly excessive loss of power on my 2000 S-10 Blazer which I'm hoping a planned tune up will help. Years ago cars had an A/C cut-off switch that basically disengaged the A/C compressor any time you floored the gas pedal. This came in especially handy starting off the line and passing on highways. My Blazer's A/C compressor does not seem to have this feature and does not disengage when I floor it -- does anyone know if it is supposed to?
Old 09-20-2006, 04:19 AM
muddog321 muddog321 is offline
AF -Advisor
Try running the AC in Norm cause MAX keeps the clutch on for more air and see if that helps - if not then as stated have AC looked at.
Old 09-20-2006, 05:07 AM
blazee's Avatar
blazee blazee is offline
Problem?
Threads merged. Posting the same question in multiple forums is not allowed.
