Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 09-19-2006, 08:54 PM
bwb01 bwb01 is offline
Question Question about ATF compatibility
Hello folks; first post on this forum. My '01 Altima is in need of a transmission fluid change. I'm a bit unsure of the correct fluid to use. Owners manual says use Nissan Matic-D. Haynes says '93 thru '01 use Dexron IIE or Dexron III and '02 and later can use either one. My local dealer says the Dexron is all they use. Can you Nissan experts please confirm I can use the Dexron/Mercon III vs. the special Nissan fluid? The dealer wants $5.82 per quart for it. Thanks for reading and have a great day/night.
Old 09-19-2006, 10:09 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: Question about ATF compatibility
Dexron III is the ATF to use. Each is compatable with the other. I don't pay $5 a qt for ATF.
Old 09-19-2006, 10:29 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Nissans Matic-D is basiclly the Same as Dexron III
Old 09-19-2006, 10:55 PM
Then how on Earth can they get away with charging almost three times what Advance or Autozone wants for Dexron?
Thanks for the help guys.
Old 09-20-2006, 12:04 AM
slideways...'s Avatar
slideways... slideways... is offline
because dexron is a GM trademark and so is the recipe and making process. so nissan has to use their formula, so it is different, but it works with hardware they designed based off the u.s. dexron/mercon system's design.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 09-20-2006, 01:15 AM
Exactly, and because Honda and others charge the same way. They have to charge that much because not as many people purchase oil with a manufactures label on it as their stock holders would like.
Old 10-14-2006, 11:33 PM
Mrbizness1 Mrbizness1 is offline
Hopefully this attitude is starting to change. This week I noticed Walmart is now stocking Chrysler oil filters and Mopar trans fluid.
