Old 09-19-2006, 08:53 PM
plastik06 plastik06 is offline
Tail light assembly corrosion
Hi guys,
My left turn signal starting going nuts and sporadically flickering really fast. Then it just starting blinking fast all the time.
I changed the burnt out DRL and rear turn signal bulb, but no change.
I was pretty pissed cuz I'd waited till I couldn't stand it blinking so fast only to find out that that wasn't the problem.
When I pulled out the tail light assembly again, I took a close look at the contacts for the bulb itself and at least 2 of them have corroded!
Anyway, tail light assemblies are pretty expensive so I wondered if anyone knew how to change just the sockets in the assembly so I can save a few bucks fixing it. That is... if it is even possible.
Any suggestions?
Old 09-19-2006, 09:34 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: Tail light assembly corrosion
Try cleaning it up and putting some dielectric grease on it. Depending on the type of connector you can get most of them a the parts store.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 09-19-2006, 10:36 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
If you are reffering to the 99', thiers no parts at your local store for these.
Other than buying the inner part(that holds the bulbs) from a dealer or used from a salvage yard.
Which the later would probly be the same bad condition.
These tail lights leak in water bad.
Take it apart and clean all the rust/corrosion out.
Then use that dielectric grease to keep them clean.
I hav a pic of what the inside looks like . tailhousingapart .
Use some good silicone sealant when you reassemble them.
Paying special attention to the top area where the water come in.
I just got done fixing my left tail a few weeks ago, same issue
1999 Grand Am SS 3.4 OHV
Old 09-20-2006, 05:44 PM
It is the '99 SE v6 3.4.
I'll give it a try with cleaning and sealing.
Thanks
Old 09-20-2006, 06:19 PM
Good Luck !
