Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-19-2006, 08:12 PM
ysteve ysteve is offline
Question Hard shift
1.Guys i saw post somewhere about tranny shift hard from R to D to R. And when i park car is moves 8 -9 inches back and forward. Axle or something maybe involved there.
2.And another shifting problem i have when iam driving, but this one i think because of low power. You can go on my post NO CAT and you can see what iam talking about. I really like my Impala but sometimes you have a porblem that even dealer cant find it and you have to spend your money to fix that.
What you think about question 1 and 2. I think they too far from each other.
Thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 09-19-2006, 08:56 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Hard shift
What year car and what type transmission?
If it's an older, pre-1987 B-body with a 700R4, the harsh-into-gear is common. Beginning in 1987, these transmissions were fitted with an auxiliary valve body, which contains an accumulator to soften the into-gear shift.
A high idle speed can also cause this, so rule that out first.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-19-2006, 09:08 PM
Re: Hard shift
Look "NO CAT" same page.3.4 2003 93000 4t65e
Old 09-19-2006, 10:52 PM
silicon212's Avatar
Confoundingly Lucid
Re: Hard shift
Possibly worn CV joints? What condition is the fluid in, and is the Service Engine Soon (Check Engine) light on?
Old 09-20-2006, 08:04 PM
Re: Hard shift
What is CV joint? Fluid is good. No light.
First i thought its strut mount then i chaged them.
I saw forum on similar problem but cant find it.
Old 09-20-2006, 11:06 PM
silicon212's Avatar
Confoundingly Lucid
Re: Hard shift
The CV joint is the constant velocity joint in the axle shafts (or half shafts). They do the same thing that U-joints do in a RWD car. If they're worn, there will be some slop in there and could cause the issue that you have.
Old 09-21-2006, 06:08 PM
Re: Hard shift
How much all this operation gonna cost? And hwo can do it?
Thank you
