Old 09-19-2006, 08:52 PM
coleld coleld is offline
1996 Cherokee 4.0 liter Dies after running very rough for 20 seconds
I just picked up a 96 Cherokee from a fella. He said it died in his driveway. He replaced the fuel pump, fuel filter, spark plugs, cap and rotor. He can get it to run for about 20 seconds very rough and then it dies. What do you suppose the problem is? Its a 4.0 engine , Automatic trans and 4x4 . Your help is greatly appreciated. I don't want to throw a box of parts at this for something simple...
Update: I just found out this evening that the reason for it's sudden death was it overheated. The guy replaced the Waterpump and thermostat but he couldn't get it started and then suspected the fuel pump and replaced that along with the filter, distributor cap and rotor also the plugs.
Thanks in advance.
Old 09-20-2006, 08:41 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 1996 Cherokee 4.0 liter Dies after running very rough for 20 seconds
Getting any codes?
My first thoughts were either for clogged cat or crank position sensor.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 09-20-2006, 11:13 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Along the lines of what Fred said.
I would change the crank position sensor if no one has done so yet.
Then I would hook up a fuel pressure gage and a Vacuum gage and take some reading. If you report back with those reading, I can give you some more ideas.
Note: I woudl "T" the gage into the injection using the shrader fitting on the fuel rail.
Old 09-20-2006, 09:15 PM
Thank you for your help... I will replace the Crank Position Sensor and let you know how it goes. I also just found out this evening that the reason for it's sudden death was it overheated. The guy replaced the Waterpump and thermostat but he couldn't get it started and then suspected the fuel pump and replaced that along with the filter, distributor cap and rotor also the plugs. Any thoughts?
Old 09-20-2006, 10:30 PM
AlohaBra's Avatar
First...give us the mileage.
Then your can pull the spark plugs, and inspect them. Then, you can do a compression test.
But, you will need to replace the crank position or (TDC) sensor sometime, so that will be a start.
Old 09-21-2006, 06:41 AM
Milage is 184,000
Ok I will inspect the plugs, they were replaced with the cap and rotor but I will inspect to be sure they aren't fouled. I plan on replacing the CPS this weekend. What is the TDC and it's function? Where is it located?
Thank you for sticking with me on this. I will update you.
Old 09-21-2006, 10:48 AM
AlohaBra's Avatar
*When you inspect the plugs, you are looking for water or rust. Hopefully none, when means..um...head gasket. Compession test...for leakage of some kind....just a precaution.
*TDC sensor and CPS are same thing (Some manuals call it that.).
Old 09-23-2006, 08:39 PM
Well here is an update... I had a short time to check this jeep out and found what I believe to be a clogged CAT . I was able to get it running but within just a few minutes the manifold pipe was cherry red. I never seen anything like it. It was amazing. So my plan is to replace the CAT and hopefully no other damage is done. Does anyone have any suggestions?
Old 09-24-2006, 12:54 AM
AlohaBra's Avatar
WOW...cherry red exhaust...glad you didn't burn up anything!
Let us know how it all goes....
Best luck...
Old 09-24-2006, 08:50 PM
I have another update. Today I cut the CAT out, I didn't put a new one on yet but it did cure the overheating problem, the temp was normal.
I still have a problem with it stalling after running for about 20 seconds. It will idle pretty good then die after 20 seconds. It will start right up though. If I keep my foot on the peddle lightly it will hold idle and sound pretty good. I tried driving it but it "Lugs" "Bucks" and "Jerks" wanting to stall. Does anyone have any ideas? Thanks in advance..
Old 09-26-2006, 11:31 PM
thinmints thinmints is offline
im assuming that since you took the cat off the 02 sensor went with it that may be part of your problem i would replace the cat and put a new 02 sensor on it see what happens with that and let us know what happens
