Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-19-2006, 06:01 PM
burberrykid burberrykid is offline
Exclamation 93 camry with light problems please help
Hello, i'm having problems with my 93 camry, the lights are not coming on , on the dash, and also the a/c lights and/ the P, R, N, D, 1, 2 lights don't come on. (park,reverse,neutral,drive,)
Please help!!!- Steven
Old 09-19-2006, 07:10 PM
somick's Avatar
somick somick is offline
Re: 93 camry with light problems please help
Have you checked fuses?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 09-19-2006, 07:53 PM
Sam
i don't know which fuse would that be under?? do you know????
Old 09-21-2006, 10:35 AM
SatchBoogie SatchBoogie is offline
Look up the fuse codes in the manual. Then in the fuse box, it will show a diagram of which code corresponds to which fuse.
Old 09-25-2006, 10:13 AM
AznGunner AznGunner is offline
I am having similar problems with my A/C backlight not coming on. Where would the fuse box be located??.. I've looked under the hood....that fuse box doesn't see to correlate with the dashboard at all...where would this fuse box be?
Old 09-25-2006, 02:04 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Try the lower left dash behind the coin holder or similar panel. If it's just the A/C light the problem is more likely a blown bulb. Every bulb doesn't have it's own fuse. One fuse normally safes many bulbs as in the entire dash.
Old 09-25-2006, 02:17 PM
so if it's the bulb....what is the easiest way to get to it?
Old 09-25-2006, 02:36 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
You probably have to remove the ventilation control panel and figure out how to get inside to change the bulb. Search the sight for related info. Check the Camry manual at the top of the forum.
