Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 09-19-2006, 03:14 PM
Kaazi Kaazi is offline
MK4 Golf Problem with lock
Hi Guys,
The lock on the driver's side of my Golf MK4 just went loose all of a sudden.
I went to open the door and instead of all the locks opening nothing happened!!!
So I opened the passenger's side door to open all locks and it was ok.
However, when I lock and unlock using the switch inside all is fine - including the driver's side door lock...
I opened up the door's panel and tried to get to the lock knob bit and see where the problem is - as it is most likely to be a mechanical problem, but I just could not get to that part...
When I took the internal door panel off, there was a metal panel on the inside which is attached to the window of that door... from there I just could not get any further to determine where the problem is...
Can anyone help? It will be greatly appreciated... thanks...
Old 09-24-2006, 10:13 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: MK4 Golf Problem with lock
If the key just spins in the lock instead of locking/unlocking you need a new lock assembly (and you can transfer over the painted cover)
Old 09-25-2006, 04:43 AM
Hi veedubmechanic,
Thanks for the reply.
The lock does not spin.
When I turn the key to the point when the locks are supposed to open, the lock just springs back...
When I turn the key to the point when the locks are supposed to close, the lock does nothing...
Therefore there is no spinning... Any further ideas?
Old 10-04-2006, 09:09 PM
VDUBMAN
Replace the door latch and the black plastic bracket for it.
