Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 09-19-2006, 02:16 PM
freebird1963 freebird1963 is offline
error message on odometer lcd
lately for now reason I get a no bu5 message on the odomoter.
I lose my rpms, speed, and other functions with the dash.
Then it will come back. Does it sporaically and no rhyme or reason.
THanks
mark
Old 09-19-2006, 03:34 PM
BLAZERBOY69 BLAZERBOY69 is offline
Smile Re: error message on odometer lcd
This Is Basically Telling You That There Is A Short Somewhere In The Elctrical System. I Had The Same Problem On My 99 Tj, And I Ended Up Pulling The Entire Cluster Out, Only To Find That A Hair Had Gotten Into The Connectors Right Behind The Cluster, And I Had Grabbed Some Of The Connector Grease, And It Was Causing The Terminals To Cross. Remove The Hair. End Of Story. I Called The Dealer About This Problem First Though, And They Told Me It Would Be Around $200.00 To Look At It, And I Would Have To Leave The Tj There Probably About Three Days So They Can Check The Entire System....... ($200.00 To Remove A Hair!)
