Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 09-19-2006, 12:53 PM
Giuseppeb Giuseppeb is offline
Exclamation 99 sebring conv. door sensor issue
My Fiance' has this car and has been telling me lately that she hears the 'door ajar' dinging sound (like when you first put the key in), the door indicator on her dash lights up and her doors try to lock. (Even though they locked themselves after 10mph or whatever the limit is). This is happening more frequently now, hence I am actually looking into it...:-)
Apparently it is random, sometimes when she is turning, over bumps, not turning, really random.
So here is my question: I have checked the door switch at the b pillar (if it werent a conv.) and adjusted the door to be sure it is not jarring around. Still have issue. Where is the sensor/relay/dohickey located under the dash? I am assuming that there is a loose connection or a bad sensor/relay, but I cannot find it! Is it an all-in-one Chrysler innovation that will cost me a kidney or something? I have an idea that it is the blue box attached to the wiring harness under the dash, but thought I would ask the pro's before ripping into it any further.
Any help or ideas would be greatly appreciated.
Giuseppe
Old 10-21-2006, 10:12 PM
mendoza46360 mendoza46360 is offline
Re: 99 sebring conv. door sensor issue
Giuseppe
i have the same kinda car just a 97 had the same problum over bumps when i turned or just did it when ever the didng and interior lights would com on all i did was were the door meets i took the star allan and made the star screw thighter on the car jam and on the door it self were the lach is this stop my problem may want to check again if you have done this and it you ever have any digital mileage were the drive and reverse are, fading or just not coming on anymore let me know at [email protected] i can tell you how to fix with out hundreds of dollars
Old 09-08-2012, 04:17 PM
DavidZanke DavidZanke is offline
I have a 2000 sebring convertible that the sensor went ballistic and started flashing interior lights like a strobe. The door sensors are on the door jamb just under where the door latches. Usually, it's the driver side sensor, since it gets used more, but since the sensors are only $6 from the auto parts store I replaced them both. They look like a little peg that sticks straight out and can be pushed in, held in place by single phillip screw attached to single wire. Very easy and cheap to replace, took less than ten minutes to do both.
