| Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models |
couple of issue
1996 oldsmobile Delta 88
i posted a thread a little while ago about wierd grinding from underneth the car. the check engine light is on i already changed the water pump fuel pump and now this. the traction light also comes on every now and then for no reason so here is my list of problems right now: -My driver door the auto lock does not unlock but will lock -check engine light - something about camshaft sensor and too much power -traction light? PLEASE HELP!!!!!!!!!!!!!!! Last edited by andrewpetersen; 09-19-2006 at 01:04 PM. |
PLEASE HELP ME ASAP!!!!!96 olds delta 88
read the bulletin thats says a couple of issues 96 oldsmobile delta 88
Re: PLEASE HELP ME ASAP!!!!!96 olds delta 88
Sorry but we do not permit running more than one thread on the same issue or a bump notification.
I have combined your old post with your new one that maintains the urgency of the matter. If you have any specific odb-ii DTCs you might consider posting them.
Re: couple of issue
Sounds like you have checked your codes, your wheel ABS sensor is malfunctioning. (Check Ohms on wheel sensors to be from 800-1400 ohms. ) Your using cheap gas, and one of your wires on the unlock circuit switch in your door is off or loose or bad crimp connection and your power steering pump or transmission is going out.
Bass |
Re: couple of issue
actually i dont use cheap gas i only use premuim and mid grade at the worst, i just change the water pump and the fuel pump. i will check the wires in the door, so the abs sensor will turn the traction off? so what do i do about the codes that i did get when i checked it? thank you again
Re: couple of issue
As far as the codes go, you can get them again at an Autozone (they will pull them for you for free). It is much simpler to diagnose a problem with diagnostic codes. You mentioned a camshaft sensor. This could be code 41 (it has a PO and something else in front of it from a PCM'ed car like yours) involving a thrown camshaft interruptor magner or (less likely) a bad cam sensor. Not fun.
-Eric 89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc. Basic H/C body info:http://www.3800power.bravehost.com/index.htm http://www.cardomain.com/ride/2318168 |
that grinding noise could be the fuel pump, my dad had his replace and now he has this horrible noise, can hear it inside and out the car, when driving or just idleing, we were told there has to be a pulsator on the pump, but no mechanic wants to do it, lazy bastards.
2009 Pontiac G6 2.4L L4 2007 Buick Lucerne CXL 3.8L V6 2007 Chevrolet TrailBlazer LT 4.2L L6 1993 Oldsmobile Cutlass Supreme SL 3.1L V6 |
