Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Omega/Senator/Maloo
Old 09-19-2006, 12:29 PM
ozzie31 ozzie31 is offline
auto gearbox transmission fluid
every now and then the automatic gearbox light comes on the display, and i have been told that it might be to check the level of the transmission fluid. anybody got any ideas as to how i do this without forking out garage prices and looking stupid?
thanks
Old 05-21-2007, 03:41 PM
tommy.h tommy.h is offline
Re: auto gearbox transmission fluid
1-park the car on a level surface
2-remove the filler plug on side of gearbox
3- start engine
oil should be level with filler hole so you should get a dribble of fluid when at the correct level
Old 05-21-2007, 07:02 PM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Pop the bonnet. There will be a dipstock for checking the auto fluid level at the back of the engine, it should have a yellow handle on the dipstick. Pull it out, while the car is off. The fluid will come up to a certain level and there will be a 'C' mark for the level the oil should be when the oil is cold. If it is low, I recommend getting an auto transmission filter change.
Driving the car with low oil will cause wear and the filter needs to be changed if you dont want the auto to destroy itself from having new oil but bits of metal in the filter destroying the auto gears.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
